Patching floor pan hole
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
I have a hole forming on the drivers side floor pan near the pinch weld and right near where my left foot sets. I'm looking at renting a TIG welder (because I only know how to do TIG thus far and want to get this hole patched before the really salty weather gets here) and fixing it properly, but I haven't been able to find out how thick the metal is there.
Anyone know how thick it is? I'll post pics tomorrow and any advice on fixing the rust is appreciated.
Car: 2003 F-150
Transmission: 4R70W
Re: Patching floor pan hole
You sure? .036" seems awfully thin for a floor pan:
http://www.unc.edu/~rowlett/units/sc...heetmetal.html
Mathius
Car: 2003 F-150
Transmission: 4R70W
Heres a picture of the hole. Its about wide & long enough for me to get 4 fingers into it. Sorry for the crappieness of the photo, my camera has a hard time focusing on close objects and I was trying to squeeze myself under the car while it was parked on some darn cold concrete.
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
looks like a easy fix hard to tell from the pic tho, I use 14ga to 16ga steel... not galvanized stop signs just wanted to point that out
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
need a larger pic of the entire area, if you are just worried about filling in the hole, and the rest of the metal is not rusted away to the point where its paper thin, you can weld a patch on.
Car: 2003 F-150
Transmission: 4R70W
Heres a pic of the larger area. While I was looking, I saw that the entire length of the pinch weld is starting to come apart, but not all the way through like in the first pic. It looks like there are multiple sheets of steel in that area.
Car: 86 Trans Am
Looks like you have some more rust to clean up too while your down there.
Car: 2003 F-150
Transmission: 4R70W
Do you think that if I patched all the holes and and painted over with POR-15 that I'd be good for awhile?
Car: 86 Trans Am
yea for "awhile" band aid fix...
Car: 2003 F-150
Transmission: 4R70W
Thats all I can afford to do now. I don't exactly have all the time in the world or tools and a very open budget for fixing it properly (thankfully the welder rents for cheap). I just need the car to not fall apart until I make it through my last semester of college in May and get a job. Then it'll be parked when I buy myself a "new" car, probably a big old diesel truck. That way I can work on getting myself some tools and fix it proper before I begin to turn it into a toy
At least I'm trying to nip this thing in the bud before I loose the floor pan
Car: 2003 F-150
Transmission: 4R70W
Here's my plan of attack since I don't have very "ready" access to the proper tools. First, I'll take a wire wheel & knock off all the rust and spray some weld through primer over the areas where I'll need to weld but won't have the time to do so.
http://www.summitracing.com/parts/SHW-DPP108/?rtype=10
I'll also prep and paint POR-15 over the rest of the floor pan. I'm thinking a quart should do fine with a paint roller.
http://www.summitracing.com/parts/POI-MRQ/
Then I'll measure the thickness of the steel, probably .036"-.048" inches and get some sheet to make patches out of. I'm thinking cold rolled A366/1008 mild steel and roll POR-15 over that.
Sound like a decent plan?
Car: 1986 Chevrolet Camaro
Engine: 355 chevy
Transmission: t-5
Axle/Gears: 3.73 disc brakes
i just bought a floor pan driver side from a guy in vancover for 299 cad, mine has a hole around the drain plug, imo these cars are unibodys and the floors are part of the frame, and when its puzzled together its not nearly as strong, and for 299 for a replacement side for a 3rd gen, id just replace it imo but i can see why for cost reasons too but nothin nicer than new floors
Car: 2003 F-150
Transmission: 4R70W
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
I just fixed this on my car... but mine was worse.
You may be surprised at what is damaged once you dig into it, like you said there are many layers of metal that come together there.
http://www.yerot.com/~aweil/pictures/rust/
check rust16 through the end... I haven't uploaded the finished pics, but it was a decent bit of work.
A MIG with .024"ish wire will be your friend here. A TIG is possible, but it's really hard to get your head into position to see the puddle. I have both, and only used the TIG occasionally.
Car: 2003 F-150
Transmission: 4R70W
Good advice on the MIG. I've done some pretty weird stuff with TIG, so its still a possibility.
Don't know what happened to my whole note but it disappeared. to make a long story short. welding is ok--you can buer small pece of sheet metal from canadian tire here in Canada for 9.99 or they have larger ones. Gooled and it said if you weld it must be from underside of car--also said you could fibreglass the hole from inside the car--check with a mechanice re fibreglass--i think that would be if it is not structural--just to keep the exhaust out. but a lot cheaper fix.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Maybe I'm getting old, but I'd sandblast the whole underside, then check for soft spots. IMO, it's just as easy to cut the whole floor with an air saw and weld a replacement than it is to make 5 patches.
Almost every project car I bought (that wasn't fiberglass) has needed some sort of repair like this. My current Z28 needed two rear quarters! Those are fun to do.
-- Joe
-- Joe
Car: 2003 F-150
Transmission: 4R70W
I'm well past this now. I'm to the point both pans need to be replaced. And I have no shop in which to do it:
https://www.thirdgen.org/forums/body...ace-floor.html
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
just further on my pan hole patch. Had my brother weld in a patch from inside the car--he sure hated using that thin(to him) sheet metal--(he welds pipelines) from Canadian Tire. It was just a hole where a plug had rusted out--but had to be fixed for safety. Then I fibreglassed over top of the welded spot--first time i had done any fibreglassing but looks ok. I probably did overkill as I put on four layers of fibreglass.It is under the floor mat so didn't need to be pretty--but i think it is anyway. Is there something i should put over top of the fibreglass?? i see people talk about PRO-1--don't know what that is. A shame they put plugs in the floor as the floor otherwise is mint. The hardest part i found of the fibreglassing was trying to make sure i got the mixture right. Mind this was on a flat surface--don't know how i will make out when i start the outside of the front fenders.
Car: 2003 F-150
Transmission: 4R70W
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
I fibreglassed over the weld on the inside because I was told that if the weld was done from the outside it would pass inspection. As the weld was done from the inside I fibreglassed it because I was told that you could fibreglass it from the inside and just the fibreglassing from the inside would pass inspection. Overkill yes, but i do want it to pass inspection.
Car: 91 Camaro RS
what inspection would it need to pass? if your in the US, then the inspection would consist of a generic safety check to make sure things like the lights and horn work and then a sniffer test (is applicable) to make sure your car falls within pollution standards.
welding a sheet metal panel in is welding a sheet metal panel in, it doesnt matter which side its welded from. the fiberglass doesnt provide any extra structural support and most likely will crack and separate from the sheet metal over time.
whoever keeps telling you these things(like using expanding foam and fiberglass to repair a rust panel)sounds like they have no clue what they're talking about, or have a degree in half-assing things.
i am in Ontario Canada--that should tell it all with all the regulations we have. It is a vehicle safety inspection that your vehicle must pass each time it changes hands if it is not a brand new vehicle. A mechanic who is has a ticket to perform inspections goes over the vehicle from top to bottom looking for safety issues, brakes, brake lines, holes that would allow exhaust into the vehicle, rust, tire tread, lights, brakes, windshield,etc. etc.
Car: 2003 F-150
Transmission: 4R70W
If you all are interested in what the pans look like, I've added pics to my other thread here today:
https://www.thirdgen.org/forums/bo...ace-floor.html (How much to replace a floor pan???)
(But then again I have only ever riveted floor pans cause I'm far too lazy).
