Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
3 different bolt sizes for the transmission cross member
Old Jan 19, 2011 | 10:20 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Maybe this thread is more suited to be posted here
https://www.thirdgen.org/forums/tran...olt-sizes.html
Old Jan 19, 2011 | 11:25 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: 3 different bolt sizes for the transmission cross member
If you have access to a welder then the proper way IMO is to cut the floor out above it, remove the nuts, weld in new ones and weld the floor back up. Otherwise there is nothing stopping you from welding grade 8 studs into the factory floor or welding bolts upside down under the frame area, none of these are the "proper" fix, they may be the "quick" fix though. Your sig pic looks like a nice car, hate to just hack it and forget about it
Old Jan 20, 2011 | 08:49 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I support cutting the sub frame with hole saw, dropping in some top notch bolts and welding them in place. Then weld the plug you cut with the hole saw back in.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
