3.1-3.4 intake
3.1-3.4 intake
i have a 3.1 motor but bought a 3.4 intake i know they are the same block pretty much the same motor except for the intake i know it will bolt down but can i use the 3.1 throttle body on the 3.4 intake or will i have to buy the 3.4 throttle body an wut do i gotta do to make that work thanks!!!!
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: 3.1-3.4 intake
Not unless you either mod it to fit with the distributor or convert to DIS(Coil packs) .
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: 3.1-3.4 intake
short answer to this thread is no dont bother
saying that do a search on my threads started to find out why it wont work
the throttle bodies wont interchange you have to use the 3.4 tb with manifold
and you have to cut the back side of the manifold to clear the distributor
or learn how to put the DIS and coil packs on your car
basically dont waste your time there is no gain, i just did it for the heck of it
**nevermind i did the search for you since most people wont do it themselves
https://www.thirdgen.org/forums/v6/3...ve-go-3-a.html
jerflash
Sep 24, 2015 03:11 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
