Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
4th gen center console
Old Feb 8, 2011 | 07:22 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Looking if anyone would post their camaros with 4th gen center console, i want to see how it fits against the bezel of heater and radio.
Also how hard is it to fit the ebrake and align it?
Also since my car is auto would the auto center console fit perfectly?
Old Feb 8, 2011 | 07:32 PM
dirtybrd88's Avatar
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
Re: 4th gen center console
search it theres a swap article somewhere good luck
Old Feb 8, 2011 | 08:29 PM
addicted2racing's Avatar
Car: 91 GTA
Engine: 383
Transmission: t-56
Axle/Gears: 9" posi 3:89 gears
did everything with a dremel...not too bad of a swap, e-brake will slide right in the slot
Old Feb 8, 2011 | 10:00 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
what did you dremel precisely? that's good to know!
What years did they make black center consoles?
Old Feb 8, 2011 | 10:12 PM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Id post pics but I have a 4th gen. Dash also
Old Feb 9, 2011 | 12:20 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
here's my car before the 4thgen dash swap. 1990-92 dash, 85-90 firebird pod, 93-97 camaro console.
Old Feb 9, 2011 | 07:08 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Thank you very much!
question though; will my auto shifter (stock) fit perfectly with the auto shifter plate on the 93-97-02 console?
Also what the the different styles of center consoles from 93-02 camaro/firebird? Looking for black too; want to know what years those came in.
Also is there a extra 12volt source i can tap to hook up the aux power outlet too?
How exactly did you get it to fit? did it fit perfectly and bolt right in? or did you have to modify it?
Old Feb 9, 2011 | 07:21 PM
mw66nova's Avatar
Engine: 7.0L
stock shifter will not work in an auto console. most get a t56 console and put the stock shifter through the boot to cover it up. this was a while ago and i can't really remember what all i did to make it fit. everything on my car has been modded, so i pretty much expect anything that goes in the car to have to be modded in some way.
as far as aux power, you can pull from the cig lighter, or go from the aux power slot in the fuse box.
Old Feb 9, 2011 | 07:38 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
do i have to modify the console shifter plate to get it to work with the shifter?
Did research, so from what I understand. to get a 97+ camaro or firebird center console thats auto to fit my 89 camaro thats auto i'd have to trim the front of the console to get the shifter to be aligned? thats all?
EDIT:
I found this: http://www.cardomain.com/ride/314802...-camaro/page-2
So basically all it works on my camaro just what about the auto shifter plate?...
Old Feb 9, 2011 | 08:11 PM
mw66nova's Avatar
Engine: 7.0L
IIRC, the shifter sits too high, so you either have to trim the shifter, pound the shifter mount pad down some, or trim the hell out of the console+shimms
t56 console looks better
Old Feb 9, 2011 | 08:21 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
wishing my car was standard but i have 2 issues.
1. i haven't droven a standard car enough
2. dont have money to do the swap
so basically just trim the **** and remold the shifter then, shouldnt be to hard. curious though, can you just swap the shifter itself from the 4th gen to the 3rd gen? direct bolt or complete different setup?
Old Feb 10, 2011 | 05:25 AM
mw66nova's Avatar
Engine: 7.0L
what part of "use a t56 console" says to use a t56? put a t56 console on there with the stock auto shifter, use a boot up to the shifter **** and it gives the appearance that you have a standard shift car, without fitment issues that an auto console will give.
they're completely different shifters, won't be a direct bolt in. would require new bracket.
Old Feb 10, 2011 | 05:28 AM
mw66nova's Avatar
Engine: 7.0L
like this car, which is actually fitted with an auto:
more pictures of this car here:
https://www.thirdgen.org/forums/memb...t-finally.html
Old Feb 10, 2011 | 06:31 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
sorry misread and thought you said for me to get a t56 not a t56 console. It looks good, i was hoping to still have the indicator but that's fine
Whats the difference from a 97+ camaro vs firebird center console or do they look the same?
Old Feb 10, 2011 | 07:34 AM
mw66nova's Avatar
Engine: 7.0L
the consoles are the same on a 98-02 firebird or camaro IIRC. not totally sure though. i know that there was a medium dark grey in the earlier 93-97 firebird consoles, and the 98 and newer got the black/ebony. the camaro console 93-97 was a different animal all together, and most people just use the 98-02 style. here's my car now:
still a work in progress
Old Feb 10, 2011 | 08:30 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I'm waiting for tomorrow or monday for the local junkyard to get in their new 70 cars in, hoping for 97+ camaro/firebird so i can grab a console! they said $20 if i self pick it rather than pay $100+ online from a member.. just to much
Old Jan 19, 2012 | 11:31 AM
WhiteKnight91RS's Avatar
Car: 91 Firebird
Engine: 305 carbd
Transmission: 5spd
sounds like a damn good deal!!!
Old Jan 28, 2012 | 06:49 PM
marokid's Avatar
Car: 86 z28,89 iroc
Engine: 350 crate and ls1
Transmission: 700r4/4l60e
Axle/Gears: open diff stock/4th gen posi
https://www.thirdgen.org/forums/inte...r-console.html my personal swap
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
LittleFranks
Sep 17, 2015 12:22 PM
Firebird sweden
Aug 16, 2015 05:02 PM
