Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Sequential taillights
Old Apr 21, 2011 | 06:28 PM
  #101
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: Sequential taillights
Originally Posted by BigBadLou
Wow, that is an awesome picture, if I may say. I like the neat wiring and all.
Very good job!
Btw, you don't have the side pocket in your left fenderwell or you removed it for installation?
Lou
The car didn't come with door keys as I found out shortly after purchasing it...so I couldn't open it till I had keys made....so ya I got screwed on that one.
Old Apr 23, 2011 | 04:09 PM
  #102
intruder's Avatar
got my sts and here is a pic of where i mounted it and a vid
Old Apr 23, 2011 | 10:18 PM
  #103
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
on the quality of lou's work... i bought from rounds 2 and 4 still going strong and getting wonderful compliments. keep it up lou. both cars love it!
Old Apr 24, 2011 | 09:34 AM
  #104
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Originally Posted by theimpaler68
both cars love it!
Thanks for the good words.
And both your cars deserve it!
Old Apr 26, 2011 | 07:40 AM
  #105
sam24th's Avatar
Car: 85 firebird
Engine: 3.4L V6
Transmission: auto
I still have my unit from way back when stephen was selling them. These things are awesome. Im glad your making them again as I might have to buy me a set for this camaro im looking at picking up. Also does anyone know where I can get some LED red bulbs for the rear that are plug and play? I'll do a search later just thought if someone had the answer I wouldnt have to look.
Old Apr 30, 2011 | 10:16 PM
  #106
intruder's Avatar
Originally Posted by 91banditt2
this video is with the stock 1157 bulbs with the 552 flasher
http://www.youtube.com/watch?v=y1KJUkOtcmc
this video is with 1157 LED bulbs and the 552 flasher
http://www.youtube.com/watch?v=DOZbOkXkOsA
i got the same flasher but mine still flash fast and it is turned down as slow as it will go, how did you get yours to flash slower
http://www.youtube.com/watch?v=kKXJSbYKgkg
Old May 1, 2011 | 12:20 PM
  #107
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Are you using LEDs?
I'm using the stock 552 hazard flasher for the turn signals.
Old May 1, 2011 | 03:40 PM
  #108
intruder's Avatar
Are you using LEDs?
yes i'm using led bulbs i got the 552 nl adjustable flasher for the turn signal. i did notice that the hazzrds flash slower
Old May 1, 2011 | 04:00 PM
  #109
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
But isn't there 2 separate flashers? 1 for the turns, 1 for the hazards?
I'm pretty sure I've pulled my turn flasher out & the hazards still worked. So if I'm right, you'll need 2 slower flashers to make it all work slower.
Old May 1, 2011 | 04:21 PM
  #110
CaliChevyLover's Avatar
Car: 1986 IROC-Z28
When I did mine, the hazards worked fine with the stock flasher, turn signals did not.
Old May 2, 2011 | 01:11 AM
  #111
hornick's Avatar
Car: 1986 Trans Am WS6
Engine: 305TPI
Axle/Gears: 3.42 (I Think)
can you put me on the list, and didn't see it, but any ETA estimates?
Any chance you can add me to your list!
Old May 2, 2011 | 01:17 AM
  #112
Car: GTA
I'm not sure what your saying there. You said "the stock flasher", but I am thinking there aere TWO flashers. 1 for turns & another one for hazards.
Old May 2, 2011 | 11:33 AM
  #113
BigBadLou's Avatar
Engine: TPI
Added you to my list, Hornick.
If you'd like to purchase a unit, just visit the STS unit page for information, instructions and payment options. I can build your unit tonight and ship it tomorrow morning.
Regards
Lou
Old May 2, 2011 | 11:42 AM
  #114
BigBadLou's Avatar
Engine: TPI
Btw, our F-bodies have two flashers. One for the standard turn signals (clipped to the side of the fuse box) and one for the hazard signals (plugged into the "convenience center"). They are separate flashers, the hazard flasher should be definitely slower (since it handles higher current loads).
The one problem that might occur (depending on vehicle and flasher) that if you use the hazard flasher in place of the turn signal flasher, the turn signal might not flash, it might just stay on (or one side will flash slowly, the other one will stay on). This is due to the design of the flashers - these are electro-mechanical LOAD-dependent flashers, not the newer style electronic no-load flashers.
Hope this helps.
Lou
Old May 2, 2011 | 12:04 PM
  #115
92z28camarokid's Avatar
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Just ordered mine! Can't wait to put em on
Old May 2, 2011 | 12:12 PM
  #116
BigBadLou's Avatar
Engine: TPI
Received your payment, thank you.
I will be building your unit tonight and shipping it in the morning!
Lou
P.S.: Very nice car, btw. Did you build the engine yourself?
Old May 2, 2011 | 12:22 PM
  #117
Axle/Gears: stock
Had the engine built by JD Performance in Crane, MO. Well known circle track engine builder that cut me a hell of a deal
Old May 14, 2011 | 01:40 PM
  #118
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Just got mine in, works like a charm, very satisfied, and apparently i have the wrong flasher in there, but not complaining. My turn signals are really slow (perfect speed for these sequentials) and my 4 ways are rediculously fast, so i need to get another slow one for my hazards and i'll be 100% happy. Thanks Lou!
Old May 14, 2011 | 03:23 PM
  #119
fishyz's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Here's mine with 3 bulbs...
http://www.youtube.com/watch?v=8lW-4vIS7XA
http://www.youtube.com/watch?v=Ss6LN...eature=related
Here's mine with 2 bulbs...
http://www.youtube.com/watch?v=kUGWT9uFlxU&NR=1
had issues at first but none after I figured out how to keep water out of the unit...All my bulbs are led...not autozone crap either. 3rd brake lights bulbs in the 2nd vid were just some ones i tried out, didn't work well in the day, got better ones.
Adjustable no load flasher was necessary for me, so there was enough time for bulbs to complete a cycle.
Painting the lenses didn't last long for me, maybe I did it wrong, don't care. Had them wrapped in vinyl. Reverse lights are 2 led strips on the bottom of the plate.
I want those for my camaro
Old May 14, 2011 | 03:43 PM
  #120
BigBadLou's Avatar
Engine: TPI
Yes, you just need a slower flasher for the hazards and you are set.
Very glad to hear you are happy. That's why I make these.
Old May 14, 2011 | 03:57 PM
  #121
BigBadLou's Avatar
Engine: TPI
That can be solved easily. I got one sitting on my shelf and will be making more next week. If you'd like one, just go to my STS page for ordering information and I can ship yours Monday morning.
Lou
Old May 15, 2011 | 01:27 PM
  #122
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Would any of you kind souls share some part numbers for
the different kind of flashers referenced above, i.e. fast, slow,
adjustable, circuit specific, etc.?
kk
Old May 15, 2011 | 08:24 PM
  #123
84redta's Avatar
Not sure of numbers at this moment, but your four way flasher is slower than your actual turn signal flasher. If you replace the turn signal flasher with one designed for the four ways you will have the slower flashers I do. Not sure, age of the flasher may attribute some of the slowness, which works out greatly.
Old May 18, 2011 | 12:13 PM
  #124
91banditt2's Avatar
Engine: 5.7 HSR
kk
The stock turn signal flasher for my 91 bird was a 225 flasher. and the stock hazard flasher is a 552 flasher. The 225 flasher was way to fast for the incandesent bulbs. the 552 flasher slowed it down but was still a bit to fast the last bulb didn't have enough time to burn bright like the inner two. i switched to LEDs and that fixed the problem. I have a no load adjustable flasher for sale if anyone is interested.
Old May 18, 2011 | 12:30 PM
  #125
Car: GTA
I tried that exact same one on incandescent bulbs & it burned up within 2 minutes, despite being advertised for any bulb & not just for LEDs.
Did you use it before switching to LEDs?
Old May 18, 2011 | 01:39 PM
  #126
91banditt2's Avatar
Engine: 5.7 HSR
If you mean the adjustable flasher no i didn't. I had ordered the adjustable flasher and two days later i was at Autozone looking at the LED bulbs and desided to give them a try. took them home put them in and was happy with the speed of the turn/hazards.
When i had ordered the adj. flasher i did not see where it said that there is a 15% restocking fee so instead of spending and losing money on this thing i'll find someone to buy it from me.
Old May 18, 2011 | 01:53 PM
  #127
Car: GTA
I put mine in (got it through Amazon).
I installed it. Turned on the flasher. Walked to the back to look. Too fast to me, so I got back inside. Shut it off. Adjusted the screw all the way down. Turned it back on. Got out to look at the speed...Nothing. Wouldn't fire up again no matter what I tried. Needless to say, I sent it back. Amazon got it yesterday & I'm waiting for the refund to be applied to my account now.
Still looking for another one, because I've never seen an LED bulb that could light up the complete lens good without looking like a small circular light behind the big red lens. That & I'd need 8 bulbs for my car. At (give or take) $10 each? I'm not gonna spend $80 on bulbs!
Old May 19, 2011 | 10:42 AM
  #128
91banditt2's Avatar
Engine: 5.7 HSR
Yeah it always sucks when you get defective parts right out the box.
Old May 22, 2011 | 08:43 AM
  #129
karl's-92'-z28's Avatar
Car: Too many cars
Lou can i place an order also?
Old May 22, 2011 | 10:57 AM
  #130
BigBadLou's Avatar
Engine: TPI
Sure thing, Karl!
Visit my STS page for information how to go about that.
Thank you
Lou
Old May 23, 2011 | 07:21 PM
  #131
msgZ28's Avatar
Hey there Mr. Lou, I'm placing an order for one now. How soon do you think it could be here? I only ask because I am moving this weekend, and want to know if you would need the new address as well. Your STS will be going on a 1979 Z28. I can't wait!
Old May 23, 2011 | 08:01 PM
  #132
BigBadLou's Avatar
Engine: TPI
Hello Adam, I received your payment in perfect order, thank you (I like it when a payment is made properly!) and your unit is going out first thing in the morning. Since you are in Houston, you should have the package on Wednesday. Thursday at the latest!
I would DEFINITELY ask you to post up some pictures of the 1979 Z28 tail lights when you're done, that would be SWEET!
Thank you
Lou
Old May 23, 2011 | 08:56 PM
  #133
msgZ28's Avatar
Thank you
Lou
I'll definitely post up some pictures, or at least a link when I'm done, but that will be a LONG time from now. As I said, I'm moving this weekend, and will finally have a garage. The work will begin a couple weeks from now, and I've got a whole lot of modifcation and restoration to go. All I have right now is an old Z and a plan. A third gen and a '70-72 convertible Vette (for the wife) will be next. Anyhow, here's a link to what I have to start with. Looking at an LS swap with a T56 just to start.
http://www.nastyz28.com/forum/showth...ight=hooray+me
Old May 23, 2011 | 10:44 PM
  #134
Car: 1986 IROC-Z28
I believe I posted the link to the adjustable flasher that I got and is working perfectly...also get used to prices for bulbs. you need a bulb like this
that burns red, burning white will make your taillights pink.
You need light to shine around the whole inside of the housing. Mine have over 30 leds on each bulb. I spent $30 per pair...x 3 pairs...just for tails/turn signals. everything else in the car is led too.
Old Jun 6, 2011 | 08:47 PM
  #135
BigBadLou's Avatar
Engine: TPI
Just as an FYI, I still have plenty of units left. I have a list of about 40 members who wanted one badly and so far shipped about 20 units.
So if y'all still want some, I got plenty left over.
At this point, all reservations are off and these are available on a first-come first-serve basis.
Lou
Old Jun 11, 2011 | 09:42 PM
  #136
83 Crossfire TA's Avatar
You've mentioned this a few times now, what LED bulbs did you use?
I got mine installed today (I think mine was from the first or second batch, way back when) and had a number of problems, none of them related to the actual unit (though at one point it did seem that way). My '87 TA is wired like the GTA instructions, but the outside and middle bulbs were swapped. I got myself into trouble assuming "I have a TA, I'll just follow those directions and swap the location of the sockets."
First I ended up with the lights running backwards (towards the inside rather then from the inside out), then when I rewired it looked like it wasn't working at all. I finally figured out that the flasher was running so fast that it was only lighting up the inside bulb.
Old Jun 11, 2011 | 09:45 PM
  #137
A couple of other things:
- If it looks confusing look at the universal instructions, those are easy, the how to do it for a specific TA/GTA instructions are confusing.
- Don't leave the center filler someplace hot. I took my taillights apart Thursday night, and my center panel sat in the car under the hatch all yesterday. The front face actually melted- there is some carpet stuck to it and the bottom is all warped, it doesn't fit back correctly and is really obvious looking at it from the top or the side.
Old Jun 15, 2011 | 11:32 AM
  #138
BigBadLou's Avatar
Engine: TPI
Unit shipping will be on hold for a week from today (6/15-6/22) because I will be out of town.
However, if you'd like, you may still submit a payment (per instructions on my STS page) and I will ship your unit immediately upon my return.
Btw, I have only 9 units left, gentlemen.
Lou
Old Jun 15, 2011 | 12:16 PM
  #139
91banditt2's Avatar
Engine: 5.7 HSR
[quote=83 Crossfire TA;4948998]You've mentioned this a few times now, what LED bulbs did you use?[quote]
Cause i keep getting asked the same questions
http://www.jamstrait.com/
http://www.autozone.com/autozone/acc...ier=343447_0_0_
https://www.thirdgen.org/forums/elec...formula-3.html
Old Jun 22, 2011 | 11:23 AM
  #140
BigBadLou's Avatar
Engine: TPI
I am back.
Only a few units left, this is the last batch.
Lou
Old Jun 22, 2011 | 03:38 PM
  #141
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
just wanted to give thumbs up to Lou - bought an sts unit from him a little over a week ago. plenty of communication of the order status, quick shipping. can't wait to get everything wired up and be on the road!
Old Jul 21, 2011 | 10:13 AM
  #142
mrrman's Avatar
Lou,
I am going to order this today. Do I need one module for each side? Can someone please confirm this.
Old Jul 21, 2011 | 11:56 AM
  #143
BigBadLou's Avatar
Engine: TPI
Originally Posted by mrrman
Lou,
Got your PM.
One unit can sequence TWO tail lights separately, with up to 3 bulbs in each.
You mentioned that you have 4 bulbs per side. You could:
a) remove one bulb and sequence only 3
b) connect 1 & 2 (counting from the inside), they would light up together and then you can sequence 3 and 4. So the sequence would go 1&2, 3, 4. At the flashing speed, it's pretty un-noticeable.
c) if you wish, you could buy two units and sequence each tail light with one unit, giving you the full 4-bulb sequencing effect.
I believe I have already received your payment (if your mailing street number is 115).
If you would like a second unit, please let me know ASAP, otherwise I will be shipping your unit in an hour or two.
Lou
Old Jul 21, 2011 | 12:12 PM
  #144
BigBadLou's Avatar
Engine: TPI
Gentlemen, I am now down to last 2 units so ....
AT THIS POINT, PLEASE CONTACT ME FIRST TO MAKE SURE I HAVE A UNIT AVAILABLE BEFORE SUBMITTING A PAYMENT.
A PM is sufficient to reach me.
Thank you
Lou
Old Jul 26, 2011 | 01:39 AM
  #145
jchaussee's Avatar
Car: 85 Z28
Engine: 327
ya. Get me on the list
Old Jul 29, 2011 | 07:04 PM
  #146
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
im definately getting one for my camaro.two questions.the stock camaro has one brake light on each side.using this kit will i still have one brake light on each side or three?question number two.i have a buick that has three combined brake/turn lights per side.will this work on it?
Old Jul 29, 2011 | 08:58 PM
  #147
BigBadLou's Avatar
Engine: TPI
Depends on how you wire it up and how you modify your tail lights. There are numerous options and it really depends on which way you'd like to go.
You can either keep the brake light separate from turn signals (possible but uncommon) or you can integrate the brake lights and turn signals to work just like on a GTA (most common) when sequencing the tail lights.
You'll probably want to change the amber lens to a red lens which is done two ways: by replacing that section of the plastic lens or by spray painting it with Candy Apple Translucent Red made by Testors (available at SprawlMart for $7, IIRC).
There are multiple threads about those modifications on this board. I'm sure you'll find a good answer there.
Yes, this unit is NOT specific to third generation F-bodies. It will work on ANY standard 12V vehicle with common negative ground. I have it on my Mustang, people have put it on old 1960's Chevies, on old Fords, old Pontiacs, I've seen them on Corvettes etc.
Hope this helps.
Lou
P.S.: If you'd like 1 or 2 units, be QUICK, I am almost out.
My STS page with all the info you might need.
Old Jul 29, 2011 | 10:57 PM
  #148
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I installed one of the STS units on my Camaro over 2 years ago and it is still going strong. The instructions are a little confusing for an install on a Camaro but Lou helped me figure them out and I'm sure he'll help you too.
I even bothered to wire in the front turn signals so my brake lights don't come on in sequence. Works great!
Old Jul 30, 2011 | 11:22 AM
  #149
BigBadLou's Avatar
Engine: TPI
That's the right way! THANKS!!
Old Jul 30, 2011 | 03:49 PM
  #150
nightstalker12's Avatar
Car: 1982 Pontiac Trans-am
Engine: carbed 305 v8
idk maby i wasnt paying attention to the threas good enuff I WANNA SET for my 82 that looks awesomly fantastical! i would love to kno how to build these not for marketing just to say i made these for my car is all any insight advice or nethg at all would be GREEEAAATT
