Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
IROC-Z AIR INTAKE TRANSPLANT TO TRANS-AM
Old Jun 14, 2011 | 02:50 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
ANYBODY TAKEN AN IROC-Z 5.7TPI 2 INTO 1 AIR INTAKE AND TRANSPLANTED IT INTO A TRANS AM GTA 5.7 TPI ??? I WILL BE DOING JUST THAT AND LOOKING FOR POINTERS. WILL POST UP PICS SOON.
Old Jun 14, 2011 | 04:47 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: IROC-Z AIR INTAKE TRANSPLANT TO TRANS-AM
it wont clear the hood.
Old Jun 14, 2011 | 05:34 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It will clear..... IF you cut the crap out of the bottom of the hood.
Dont do it.
look for and buy a used SLP cold air kit and b happy.
No need to try n reinvent the wheel.
Old Jun 14, 2011 | 07:02 PM
Dark Ember's Avatar
Car: 90' Firebird Formula 350
Ttop350 is right, it will only clear if you cut off all the supporting braces from the underside of the hood. I bought a camaro airbox like the one you are talking about and tried to make it work, but once I realized I would have to remove the hood braces, I dropped that idea. I was afraid that the hood would tweak and bend over time as its opened and closed without those braces.
Check here, this is what I did, and I posted track results also.
https://www.thirdgen.org/forums/fabr...i-ram-air.html
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
PestilenceIV
Aug 20, 2015 02:33 AM
kyle5647
Aug 15, 2015 11:56 PM
