Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Can I see some pictures of people who altered/eliminated the front strut towers
Old Feb 2, 2011 | 07:49 AM
npersha's Avatar
Can I see some pics of people who have eliminated the front strut towers and fabricated their own. I have a back-halfed drag car, but has the stock front fenderwells and want to lighten it up a bit and make it more accessable to work on the engine with them gone.
Now I know its a structural thing to the unibody, but if your car is caged and you have front hoops in the engine compartment, I am sure that is way stronger than some sheet metal fenderwells.
Any input? I am used to my 2nd gen camaro where there is a frame at least.
Thanks, Nathan
Old Feb 2, 2011 | 08:47 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can I see some pictures of people who altered/eliminated the front strut towers
There were pics of a white car in the Fabrication board somewhere a few years back.
Old Feb 2, 2011 | 01:22 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
it's this car(not my car), this is a mod i want to do to my car one day since i have a salvage title from a crash.Name:  camaro3.jpg
Old Feb 2, 2011 | 01:45 PM
DAVECS1's Avatar
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
Wow that is awsome! That would make some serious room for forced induction. Will the fender bolt right back on?? Could make a sweet strut tower for that. If you made it a little bigger I would not mind feeding a coil over into it.
Thanks for posting that. Just when I thought I had seen all the mods I could ever make there is a new one :-)
Old Feb 2, 2011 | 01:48 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Old Feb 2, 2011 | 01:55 PM
U.S.Marine09's Avatar
Car: 1986 Berlinetta, 1988 Iroc-Z
Engine: 305 carb, 305 TPI
Transmission: 700r4, 700r4
Axle/Gears: stock
wow thats pretty serious but i dont think i would be comfortable with that on the street accident protection wise
Old Feb 9, 2011 | 01:47 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I was just thinking of this car the other day... Does anyone know if it was ever completed? Yeah, I wouldnt be too comfortable getting into any kind of front end collision with it. Wouldnt be my choice for a daily driver, but thats why I have more than one of these!
Old Apr 13, 2011 | 02:24 PM
Andre#4's Avatar
Car: tta drophead coupe, 91 form 1LE
Engine: lc2, lb9
Transmission: 2004r, mm5
Axle/Gears: 3.27, 3.45
accident shmaccident. Put in a 1990 air bag setup for cushion effect.
ever see how a lotus esprit turbo is made? Basically same as a golf cart. suspension is bolted to plastic golf cart tub. Hit something and it cracks in half. front of car breaks right off. Been there done that. To fix it, the lotus dealer orders a 1/2 Lotus from Hethel, England, and they cut the car in half, right through the passenger compartment. 2 halves are glued and screwed together!! Wish I still had pictures of this. these other cars show the breakage.
Attached Thumbnails Can I see some pictures of people who altered/eliminated the front strut towers-yellows4s_01.jpg   Can I see some pictures of people who altered/eliminated the front strut towers-smashed_bluev8_03.jpg
Old Apr 13, 2011 | 02:30 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
It looks fine as is for drags but it looks like it would need a lot more cross bracing to get the original stiffness back for cornering. Yes? No?
Old May 29, 2011 | 09:07 AM
Ross85Camaro's Avatar
Car: Working on an 85 Camaro.
Engine: Hopefully 383 Stroker
Transmission: Will be a Power Glide
Axle/Gears: Undecided, thinking 411's maybe?
I too would be very interested in seeing more pics of the white car. I started a thread a while back about "Dropping some weight". A lot of people are against removing the wheel wells. Just like npersha, I dont need them in a drag car and they are in the way. 90irocdx3, where did you find those pics and are there more of them? It would be great to see the step by steps, or even detailed pics of the finished front half.
Old May 30, 2011 | 05:16 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
If that front is backed up by a full cage and subframe connectors another 3 tubes, a wonderbar and something that works as a strutbrace it's going to be stiffer then the stock setup, provided the engine comes in the front (which seems to be the case given the K-member)
With just a strut brace it should be about as stiff as stock
Old May 30, 2011 | 03:09 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
i found these pics on this website prob 3-4 years ago i don't remember the thread
Old May 30, 2011 | 04:54 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Rumor has it the owner sold it a while back. Heard he wasn't a member though.
Old May 31, 2011 | 07:02 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Ed sold the car long time ago. Here are all the pic's of that front clip. Deff. has enough brace for the street.
http://www.cecoatings.com/images/oth...0Front%20Clip/
Old May 31, 2011 | 07:10 PM
Steel Armadillo's Avatar
Car: '85 Sport Coupe/Z28
Engine: N/A 350
Transmission: TH350
Axle/Gears: Factory 10-bolt w/3.08
After looking at it, I highly doubt if any weight was saved there. But many things were likely gained, rigidity not the least of which.
Old May 31, 2011 | 07:23 PM
I think it would be a drop in weight, until I saw the mounting bar (s) for the front clip lol, that looks heavy!
Old May 31, 2011 | 07:24 PM
Thank you FSTFBODY for the pics! : D
Old May 31, 2011 | 07:51 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
It was all 4130 chrom-moly tubing ( light, strong structural tubing)
Think the same thing chasiss cars are made from.
Old May 31, 2011 | 08:34 PM
I wonder how he mounted the radiator back into that. Guess if he can fab all of that, the radiator shouldn't be a problem lol
Old Jun 1, 2011 | 07:01 PM
UnfinishedBusin's Avatar
Car: 1985 IROC Z-28
Engine: 5.7L 350
Axle/Gears: 3:83
OMG I'm in love with the flip front!!!
Old Jun 14, 2011 | 10:24 PM
highoctane's Avatar
Car: 88 iroc z
Engine: 427 small block stroker
Transmission: th400 built
Next time my engine comes out I'll deffinitly be doing somthing like this
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
