Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
TPI LSx manifold
Old Jun 29, 2011 | 12:21 AM
INTIMIDATOR Z's Avatar
Car: 1987 IROC
Engine: Turbo 293ci 4.8l
TPI LSx manifold
dunno if itll work but i thought itd be funny to make a TPI intake for lsx motors. it wouldnt look exactly like the factory one but itd be cool to use the upper manifold.
if i knew how to photoshop id make an example. with i knew how to weld aluminum too.
get these flanges and weld some tubes to the upper intake.
http://cgi.ebay.com/ebaymotors/LS1-I...#ht_663wt_1165
Old Jun 29, 2011 | 03:29 PM
Pocket's Avatar
Car: 91 Trans Am
Re: TPI LSx manifold
A LSx car style intake is pretty much a TPI intake with the plenum on the bottom and everything cast as one piece
Old Jun 29, 2011 | 05:09 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Yes, putting a LS6 intake on a TPI engine would be a better choice, if it could be fabbed up.
Old Jun 29, 2011 | 07:17 PM
Car: 1987 IROC
i just thought the look of it would be pretty cool and funny.
Old Jun 30, 2011 | 08:36 PM
83 Crossfire TA's Avatar
nice idea, even though I'm not a big TPI fan, but I do have to admit that the tpi is one of the better looking V8's that GM made in the last 40 years or so... _If_ someone wanted to do it with the ability to do it, properly designed there isn't any good reason why it couldn't make good power with just some slightly larger runners and plenum then the original TPI...
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
