Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
What to get?? cam
Old Jun 19, 2011 | 01:47 PM
onlychevy's Avatar
Car: 1992 camaro
Engine: v6 3.1
Axle/Gears: 373
What to get?? cam
I have a 1992 Camaro RS with a V6 189 3.1
I was wondering what would be a good cam to go with.
i want a little thump out of it, but also to perform well. the car only has 63,000 miles on it.......
I have ---venom high injectors
---Pacesetter performance headers (ceramic)
---MSD ignistion coil
---K&N air filter
---venom performance chip
Old Jun 19, 2011 | 02:55 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
Re: What to get?? cam
---K&N air filter
Im running this cam in my Fiero:
http://www.summitracing.com/parts/CRN-253941/
sounds good, nice lope and good performance. That cam is about the largest you can run before piston to valave clearance becomes and issue
Old Jun 19, 2011 | 03:22 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
You should probably ask that question in the V6 section.
Old Jun 19, 2011 | 04:11 PM
onlychevy's Avatar
Car: 1992 camaro
Engine: v6 3.1
Axle/Gears: 373
what year fiero and what liter engine
Old Jun 21, 2011 | 09:52 AM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
87, rebuilt 2.8 .040 over so 2.9
Old Jun 24, 2011 | 05:19 PM
onlychevy's Avatar
Car: 1992 camaro
Engine: v6 3.1
Axle/Gears: 373
I think im going to order the cam in the link
Old Jun 24, 2011 | 11:14 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I'm pretty sure thats more of a turbo cam.
Old Jun 26, 2011 | 05:55 AM
onlychevy's Avatar
Car: 1992 camaro
Engine: v6 3.1
Axle/Gears: 373
ok what cam do you think I should drop in
Old Jun 26, 2011 | 06:19 AM
Engine: 3.8, 3.4
a 260 grind is about the largest advisable on a street car, and without ecm tuning, comp cams and delta cams both have a 260 cam, though while they are similar they are not the same cam. The comp has a tighter LSA and would be the better option if you don't plan to do much modding, it is more expensive though. The delta is more peak horse power biased and has less low-mid range torque.
Old Jun 26, 2011 | 01:26 PM
onlychevy's Avatar
Car: 1992 camaro
Engine: v6 3.1
Axle/Gears: 373
how this look -- do u think this would be good price seems right
COMP Cams K16-232-4 - COMP Cams High Energy Cam and Lifter Kits
View Image and Compare
Cam/Lifter, Valvetrain, Hydraulic Flat Tappet, Adv. Duration 252/252, Lift .425/.425, Chevy, 2.8, 3.1, 3.4L
Part Number: CCA-K16-232-4
Estimated Ship Date: Tomorrow
Transaction
Old Jun 26, 2011 | 04:02 PM
Engine: 3.8, 3.4
Imo that cam is a good choice if its the last of your performance mods, but if you wind up getting a full exhaust, and or freer flowing intake setup I would get the 260.
Old Jul 1, 2011 | 03:06 PM
onlychevy's Avatar
Car: 1992 camaro
Engine: v6 3.1
Axle/Gears: 373
Thanks for all your help
I have decided to go with a 260 delta cam
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
