New bird flip-up light mod. A new direction, literally.
#101
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: New bird flip-up light mod. A new direction, literally.
where did you get all the building materials from?
#102
thanks for the info guys, but im not looking to have the fogs on with the high beams. Im trying to do this all without cutting the factory wiring (except the bulb pigtails), so i can swap back and forth to the stock setup if needed. The plan is to splice 3 pin weather pack connectors onto the factory bulb pigtails so i can just plug the factory or projector setup into the body harness when i swap back and forth. It would also allow me to lengthen the factory wiring to the stock flip ups since they are a tad on the short side and a bit difficult to unplug.
Before that, i just used male spade connectors, which fit perfectly into the sockets as well...but for a more finished and professional install, you can get the pigtails.
Or wire weatherpacks like you were saying....but with the male plugs everything factory stays untouched. Just a thought!
J.
#103
the 91-92 cars have a different plug configuration than the earlier ones, like this " / _ | " in stead of " | _ |. I could plug my harness into the 86, but not the 92. I supposed i could have found and changed the pigtail, but the original plan was the weatherpacks, so i stuck with it.
#105
1 Post
Car: 1984 Firebird (89 Formula Clone)
Engine: 357
Transmission: m29 T56
Axle/Gears: 3.27 9 bolt Borg Warner.
That is absolutely amazing. I sorta want to also attempt this.
#107
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Never happen, he has to help me get the C4 IRS under my car before he starts selling stuff to other people Plus I know he has other plans and he is always working on something
#109
So, have any of your firebird guys here with projectors actually get the fogs to work properly and still have hi/low beam function? I think not right?
i looks like i will have to add a N/C relay to the highbeam relays negative coil wire, activated by the low beam chassis wiring to get the highbeam relay to drop out when i switch back to low beams. It seems that there is enough voltage/current getting through the fog light relay to keep the high beam relay closed when switching back to low beams. Only way i can see to stop this, without loosing the fog light, or having them on all the time, is to add a 3rd relay, and it has to be one the ground side.
thoughts form the peanut gallery?
a crude wire diagram for what i think i need to do
#110
#111
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
and thats whats been killing me.
i dont got that much, i found a dollar today ....but on my way home from the store i lost a ws6 centercap so theres no way i can afford that
#112
Car: 92 Firebird
Engine: 4.8 LR4
Wouldnt it be easier to put in a NC relay for the fog light? And have the +12 wired to the solenoid for the high beam be easier/less complicated? So instead of applying +12 to both sides of the fog relay, instead you would have the high beam also activate the relay and OPEN the NC relay you put on the fog? More like factory that way?
#113
might not be following you there james, but that seems like it would still have the same issue as stock. In stock form, when the high beam is on, the fog relay has + on both sides, so it doesnt work and it open. Adding the NC relay in the fog circuit would leave the circuit the same as it was from the factory. When the low beams are on, the relay is closed, power is still flowing through it, to where the hi beam filiment used to be, and would still make the hi beam relay stick. Right? i could be wrong, my brain is not awake yet today.
the problem i have, now that i removed the "ghetto rig" temp setup and installed it more permanently, is that once i turn the high beams on, and the fog light switch on the dash is on, i can no longer turn the hi beams off, whether the headlight switch is in hi or low. It seems i have just enough voltage/current leaking through the fog relay, combined with the load across the load side contacts, to keep it closed, or "stuck". Until i turn the fog light switch off, then the relay opens again.
wiring a new relay in my original idea would be simple, i would just have to cut the ground to the hi beam relay and splice the new relay in its place. This also allows me to avoid cutting in to the body harness, which i trying to avoid. PIg tails can be replaced easily, but i dont like splicing in and out of the factory wiring.
#114
Car: 92 Firebird
Engine: 4.8 LR4
#115
sorry im a week late for an update, but as usual, things have taken longer than i hoped for.
Made progress on the bezels. They are still in a rough state, but all i need to do to finish them is to fill the low spots and a couple voids and finish sand them smooth, they are fitted and ready to go otherwise.
The only wrap around the front and side, not the back. The back will be a separate piece to i can change the bulbs.
both
the lense will simply be a piece of 3/16 polycarbonate mounted across the face,sealed and probably be painted somewhat. that all arrives tuesday.
both
#116
now on the car,
the are secured by the 2 screws on the side, and another will be on the opposite side, down in the wedge, using the other door mounting points and a small bracket i have to make once i get these off the car.
#117
driverside, and i painted it black real quick to see what it looked like. The rest are just primed to i can see the high/low spots better.
im mostly happy with them so far, i may try something different latter, but for now, these will get me moving. Fiberglass is a mess, and the garage shows it. everything is white, as well as most of the driveway....
#118
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
friggen awesome. your car looks like it wants to eat people....
#119
hahaha wow... i need to come on this forum more often again! i guess you liked the projectors i used? they are pretty awsome! i Just got mine of the road after the BBF swap and they are working beautifully.
This is a pretty cool idea! i like wat youve done. I had a problem with the mini projector since its a real HID projector the sides are completely open and they throw alot of light out the sides. Plus u cant seal the sides off bc the bulbs will overheat and burnout not to mention bake the chrome off the housings.
I would make the black on the sides a flat or low gloss black (hot rod black), not a fan of the gloss. Still tho its this very different and ill be watching to see how it turns out.
#120
my concern is moisture. I can seal the front lens and such, but like you said, i cant seal the sides of the projector. I dont know how resilient to moisture the bulbs are. I can make splask gaurds, which is the plan, but i dont know if it will be enough? good thing i have spare bulbs, but i would rather not have to replace the constantly.
#121
the bulbs should be fine. as long as they dont get splashed with water when hot. My lenses fog and get a decent amount of condensation when the weathers temp change drastically. Yet the bulbs are still working and my HID kit is a 55w.
You need to protect the housing/lense/bulb from debris and water but have to allow a cross flow of air to cool the bulb and housing while being used... if you want the bulbs/housings to last longer. This was what i was told from theretrofitsource.
Also the bixenon projectors require special one way resistors that are used. I forget what your problem was with the low beams shutting off but i hope your using a seperate relay for the headlights that uses the stock H4 bulb Hot wire from the cars stock harness to trigger the relay. Thats how mine is setup with the resistors and it works flawlessly.
#122
Also the bixenon projectors require special one way resistors that are used. I forget what your problem was with the low beams shutting off but i hope your using a separate relay for the headlights that uses the stock H4 bulb Hot wire from the cars stock harness to trigger the relay. Thats how mine is setup with the resistors and it works flawlessly.
I can seal the glass projector to my bezels with foil tape, that should reduce the condensation, but i would like the keep the projectors open for cooling. Im hoping simple splash gaurds will keep the water off them when i hit a puddle.
#123
it did not, but it had the harness for the stock foglight switch, after i think a couple of mods to the stock connector the fog light switch from a transam popped right in. A simple hot + wire was run to the front of the car for the individual fog lights. Grounded the bulbs to the car. and walla! stock fog light switch that activates the foglights independed of the HIDs which turn on through the stock headlights switch.
My problem with the HIDs was when the high beams were activated the low beam/hid bulb shut off. The special resistors allowed the feelback of current from the high beam selenoid to stop the low beam shutoff.
I havent driven the car in the rain yet. but the splash guards under the front bumper should work fine. Im more worried about the wheels flinging water to the front of the car in inside the bumper/HID shroud. water mist could be a problem. But that is why i liked the halogen projectors bc they were completely sealed. With you 35w kit you really dont have to worry about heat that much, they worked in a sealed halogen projector without burning out. However the 55w's put out alot of heat, while on for maybe 2 min the housing can give me a nice burn.
#124
but your formy does not have factory fogs does it? thats my problem. the factory fog light relay is grounded through the highbeam filament, so with the proper harness from TRS, the high beam relay sticks because of current coming back through the fog relay when the fogs are active. With the switch on the dash for the fogs off, all is well, with it on, the relay sticks once i switch the hi-beam circuit on. I have to add another relay to fix this, which should not be too hard.
The bezels look great! They will look 100x better when painted satin black vs. gloss. You did a really good job with them...should look fantastic when youre done. I dont know if you show the car...but you'll get some attention for this if you pop em up during a show!
J.
#125
I didnt really dig into your electrical situation much. But when I was looking to add projectors to my car, I came up with some ideas and all of them used a diode to keep things from back feeding. Have you considered putting in a diode to keep that current from back tracking? Probably have...just wanted to mention it.
J.
J.
no shows, this one is more of a DD, with some modifications.
a diode may work, im unsure though. I already have a plan and ordered the extra relay, so im going that route for now.
#126
Got the wiring finished up, the NC relay worked fine, but i had to add another diode the the wiring harness. Only quirk i have is the high beam indication light is always on, its really dim on low beams, and bright on high, so its still bleeding through something. If I turn the fog light switch off, the indicator light goes off like it should on low beam. Not really worried about it.
The lights are 95 percent finished, and the maiden voyage will be tomorrow after i finish installing and setting up the driverside light. I'll have pics of that tomorrow.
The interesting tidbit from the evening, i weighted the complete headlight including light and ballast. Came to 10.25lbs, vs the stock 9.7 lbs, so they are a half pound heavier, much better than i though, so i basically added only the weight of the ballasts and some wiring.
Had the car outside yesterday is a downpour while trying to aim the headlights, so they got a test in the rain and survived, which was good news. I got soaked, and the car got a much needed bath.
#128
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Nice
(insert inappropriate phrase here)
Nice
Nice
#129
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
love it
#130
thanks!
i have been stupid busy lately and have not had time to finish these or update this thread. They are installed in the car, and i have been driving with them for about a month. So far so good, but they do still vibrate a little, so i have a little work to do to stiffen up the doors a tad. Other than that, they are awesome...
#131
Ok guys, here are some pics from this summer before i installed these. This is the near complete housing ready to install. Only part not built is the rear cover, i starter, but have no time to finish it, so hopefully this winter/spring.
shows the light mount
#132
Car: 91 Camaro RS
im guessing the alum tape is there as a light barrier, not actually holding the projector in the housing?
#133
in the car
Had a couple issues arise since the last update. My fogs shorted out, and i dont know why. I dont need them, but i need to figure that out.
then earlier this week the passengerside motor ate the gear, so it needs a rebuild this winter.
Other than slight vibration issue that i need to resolve, these things turned out pretty sweet.
#134
the projectors are held in with a nut on the backside you can see it in the last pic above
#135
Car: 91 Camaro RS
now all you need is that classic shark mouth paint on the front bumper cover to make it look really angry.
#137
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
Looks good!
I think you need to change your SN to \\<86TA>//
#138
Car: 2008 C6 / 1982 Trans Am
Engine: LS3 / Hybrid LS1-406 SBC
Transmission: 6L80 / 4L60E
Axle/Gears: 2.56:1 / 3.23:1 4th gen Posi
The vibration is going to be difficult to completely get rid of with the pop up. My projectors vibrate something terrible in my pop ups and I read of a couple C5 Corvette guys that have difficulty with it as well.
#140
Oh I almost forgot... output shots!!!
One more thing, be glad you went with the Mini H1 and not the D2S version like I have.
Also if you want more usable light output use a bulb with 4300K color temp.
www.theretrofitsource.com
Mods, please remove the link if it's not allowed ^^
#142
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
i think the d2s work great...not sure why you dont.
this pic is the first i hadnt aimed them yet...they have a 6k bulb in them, white with just a hint of blue.
on topic...if your car was sliver it would be spot on johnny 5, i dont care for it but good job on it, looks like good work.
#143
#144
Well my only qualm about the D2S version is that it really lacks a hotspot and intensity along the cutoff. The H1 version has more of both. There are comparison shot of the output of both projectors and there is a significant difference. That lack of a decent hotspot really holds the D2S back in distance lighting.
#145
Car: 1985 Trans Am
Engine: 6.6 at least
Transmission: T-56 (waiting)
Axle/Gears: 9" w/4.56 & spool (4 now)
You got some mad skilz, i think it looks bad ***....
#146
Car: 1985 Trans Am
^^^WTF....did I just get sensored on a lil 3 letter word.....
#147
yeah....you did..
#148
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
That is no surprise....Hanging the big projector housing off that "small" mounting on the very back that they say to use. If I ever finish my custom mounting, I can pretty much guarantee you it ain't gonna move any.
#149
I'll dig up the comparison shots of the H1 vs D2S minis and post them.
#150
actually, thats not what vibrating. That connection is solid. I just have a little play left in the hinge i have to correct with some different bushings. That and i believe the filaments themselves vibrate, which i can do nothing about.
