new gauges in my 91
Car: 1991 Camaro RS ttops
Engine: 00 383
Transmission: t-5
Axle/Gears: moser 9" 3.50
new gauges in my 91
so i have the stock gauges on my 91 camaro rs. i want to go to some mechanical gauges that look good. everyone and there grandma buys a three pack and screws them to the dash. id like to make this look clean if its possible. are there any gauges that actually go in the stock dash panel and look good? pictures would also help too if you can! thanks
Car: 1991 z28 convertable
Engine: TPI 383 Procharger P1SC
Transmission: 6 speed
Axle/Gears: 373
Re: new gauges in my 91
Go to www.classicdash.com and you can buy what your looking for. They just came out with 1990-1992 guages and panels. Nice stuff but pricey $949.00 for everything this will be my next purchase for my Z-28.
Car: 1987 Trans Am
Engine: LQ9/L92
any reason why you're set on mechanical gauges? they may be a bit more, but electric gauges are much easier to install and don't require you to run oil and lines through the firewall. also keeps down the size of the hole you'll have to drill in the firewall, since wiring is much smaller in diameter than probes and oil lines.
