Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom gauge bezel questions
Old Sep 13, 2011 | 02:13 PM
Badrs2810's Avatar
Car: 91 camaro rs
Engine: 305 (350 vortec in dec.)
Transmission: Wc-T5
Axle/Gears: 3.08 (3.42 in dec.)
I am about to build a custom gauge bezel with autometer gauges, my question is.... I don't have gauges yet... I know the hole size.... 3-3/8" but the ring that goes around the face, to fasten it tight, does anyone have the outside diameter of that face-ring? I'm making it inset, gauge and outside face-ring.. Any ideas of that diameter
Old Sep 15, 2011 | 03:14 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Custom gauge bezel questions
all gauges arent made the same, so no guaruntees the measurements somone gives you would be specific to the gauges you use. what line of autometer gauges are you planning on using?
Old Sep 15, 2011 | 04:20 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
They are autometer phantom, 3-3/8 and 2-1/16", white face black outside ring, if that matters.
Old Sep 15, 2011 | 04:44 PM
travis401's Avatar
Car: 91 Camaro RS
i run autometer ultra lite II's. i can measure the total diameter tonight, but no guaruntee itll be the same like i said
you might try sending autometer an email and see if they can supply exact measurements.
Old Sep 15, 2011 | 04:57 PM
Badrs2810's Avatar
Car: 91 camaro rs
Transmission: Wc-T5
True, it'll be a good idea, close estimate I'm sure.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
