Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Headlights need a mod
Old Sep 23, 2011 | 11:11 PM
blue birdy 87's Avatar
Car: White 84 z28
Engine: Chevy 350
Axle/Gears: Posi and?
87 firebird and im sure like most peoples cars here the pop up part of the lights suck. They dont pop up. Whats the easiest way to make them work? Thanks
Old Sep 23, 2011 | 11:14 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Headlights need a mod
Check the dual relay box on the firewall. You might need a new one or just rebuild yours. If both headlights are failing, it has to be something that affects both like the dual relay box.
Old Sep 23, 2011 | 11:26 PM
Car: White 84 z28
Engine: Chevy 350
The motors turn on and go, the healight lamps shine light, but the mechanisms wont make them go up and down on their own. Im the guy that hits the switch then gets out and pulls them up.
Old Sep 23, 2011 | 11:29 PM
Car: GTA
Ah...
http://www.top-downsolutions.com/del...pair-p-87.html
Old Sep 24, 2011 | 12:06 AM
Car: White 84 z28
Engine: Chevy 350
Easy kit to install? 30-40 min? And thanks for the link dude i think ill be trying that
Old Sep 24, 2011 | 09:42 AM
83 Crossfire TA's Avatar
what will fix them depends on what is wrong.
When you hit the switch do the ***** on the top of the motors spin? If not then you have an electrical or motor problem, if they do then you have a problem with the gears/3 little drive bushings/linkage. I suppose you could also have the case where the motor tries to spin but the linkage is jambed preventing it.
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
