Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fabricating my own torque arm mount
Old Oct 10, 2011 | 10:54 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Because my Currie 9" housing was pointing my Jegster torque arm at the floor, I had to come up with a solution. Here's why:
So I started by cutting the Jegster mount apart:
Then I removed the housing from the car so I could work easier. Using some cardboard I started designing the top plate:
Since the bottom is identical, I just made 2. Then transferred the design onto 1/4" steel:
Then drilled holes:
Then cut the relief to mount to existing bracket:
Old Oct 10, 2011 | 10:55 AM
Car: '91 LS6/T56/9"
Engine: LS6
Re: Fabricating my own torque arm mount
Then tacked in place:
Then added gussets and welded:
Old Oct 10, 2011 | 10:56 AM
Car: '91 LS6/T56/9"
Engine: LS6
Then primered and painted:
Old Oct 10, 2011 | 11:28 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
from one fabricator/welder to another, excellent work & welds. top notch!
Old Oct 10, 2011 | 11:31 AM
Car: '91 LS6/T56/9"
Engine: LS6
Thanks. I have a millermatic DVI (dual voltage input) but only have 120VAC service in my garage currently, so I had to make due.
Some good torch preheat and everything worked well.
Old Oct 10, 2011 | 11:55 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
theyre fine looking welds. i used to have a synchrowave 250 at home. man, i miss that machine. i love to tig just about anything. its so much cleaner. now i have a POS $79.oo harbor freight flux core terd. LOL. it does the job though. tools are important to a good fabricator.
morrow
Jan 13, 2024 12:29 PM
deracer
Apr 11, 2016 12:04 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
