Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
How could i make a 2 inch Cowl grille?
Old Nov 3, 2011 | 03:59 PM
88TransAmGuy's Avatar
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
I got a hood with a 2 inch cowl from the junkyard. It didnt have a grille in it so i was wondering if i could make one or maybe find one? And if i were to make one, what would be the best material? I was thinking Screen door mesh or maybe something thicker. Heres my other thread for restoring the hood for pics
https://www.thirdgen.org/forums/fabr...g-plastic.html
-DylanN
Old Nov 3, 2011 | 04:23 PM
mitchberry's Avatar
Car: 99 SS G2
Engine: 389 rwhp ls1 n/a
Transmission: viper spec t56
Re: How could i make a 2 inch Cowl grille?
i just answered one of your questions on the other thread... so...... im going to keep this one much MUCH shorter...
YES.. you can make one..
best material would be carbon fiber..
best way to do it is to find a GOOD OEM one and make molds and put them together.
you can paint carbon fiber, or it looks cool "raw"... if you want something to actually keep stuff out then get some of the aluminum with holes drilled in it and cut it out. it has a name but i don't remember right now... people use it on grilles or whatever else.. it's not coregated metal, and it's not expanded metal. just metal with holes punched in it.. steel or aluminum work, but aluminum polishes to a shine... then spray clear coat over it and they stay shiny until the clear wears off... (years)
just use cardboard to draw a template, then cut the metal out..
pretty easy really.
Old Nov 3, 2011 | 04:24 PM
mitchberry's Avatar
Car: 99 SS G2
then again, expanded metal COULD look cool if you got the right pattern
https://www.google.com/search?hl=en&...w=1882&bih=950
Old Nov 3, 2011 | 07:39 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
You mine like mine? Just cut holes in the side, get some grill mesh material, and glass it in, I think you can also use seam sealer too or something like that, on my hood the original owner had used some kind of putty like stuff.
Old Nov 3, 2011 | 09:11 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Have something custom made like this... Someone sent me that plastic grill for their hood. He Wanted something custom out of aluminum. So this is what I made him.
Sorry about the cell phone quality pics. Will have better ones this weekend once fully polished.
Attached Thumbnails How could i make a 2 inch Cowl grille?-img_20111103_065259.jpg   How could i make a 2 inch Cowl grille?-cimg0339.jpg   How could i make a 2 inch Cowl grille?-grill5.jpg
Old Nov 3, 2011 | 10:28 PM
Thanks for the input guys.I might just go the custom route like FSTBDY said.Im still indecisive. Thanks for all the help though guys! I appreciate it
Old Nov 6, 2011 | 12:14 PM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
I wonder why that would be the best.
Please explain which benefits carbonfiber would have in this application over other materials. I´m curious
pretty easy really.
it´s not corrugated. It´s called perforated sheet metal.
The expanded metal mesh you mentioned would also work just fine and is quite easy to cut to size and glue in place.
The custom grille FSTBDY made also looks excellent
Street Lethal
Apr 30, 2019 12:14 PM
silverstang84
Exterior Parts Wanted
Sep 21, 2015 08:05 AM
eddie jr
Aug 25, 2015 06:52 PM
LittleFranks
Aug 20, 2015 03:55 PM
mustangman65_79
Aug 12, 2015 06:39 AM
