Thinking of relocating battery to behind pass wheel well?
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Thinking about relocating my battery to where the blower motor, AC accumulator, evaporator and heater core were, behind the pass side wheel well, I don't like having that much weight in front of the wheels, but do not wish to relocate to the trunk because of the weight the wiring would add.
Anyone relocated it to there and have any pics? Also wondering if there are car batteries that are more vertical mount friendly, ie. taller, but less wide and long, because it is kind of tight over there.
Car: 82 Z28
Transmission: TH350 for now
Re: Thinking of relocating battery to behind pass wheel well?
I have nothing to add other than I am thinking about the same thing...
Well I do have one concern, the weight will be up higher...
Engine: 3.8, 3.4
Not by much from what it looked like, only an inch or two, a few new cars are actually putting there batteries in almost that exact spot.
never mind, didn't read.... not a lot of room there BTW
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If it's only for street use, you can do anything you want. If you intend on going to the track, any battery that's not in the OEM location will still need a master switch installed at the rear even if you have a 13 second car. That means running 2 cables to the back.
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
a lot of the boxes I see are for 24 series batteries which is pretty big for that spot. try a 55 series, you can get them with some good CCA and they're tiny by comparison.
eightsixseven
Dec 16, 2024 01:50 PM
