interested in 91/92 rocker fiberglass ground effects??
Car: 87 formula
Engine: 350tpi
Axle/Gears: stock posi
As the title says, would anybody be interested in a pair of fiberglass rocker ground effects for the 91/92 firebirds? $200 plus shipping each pair. they will be molded off mine, and will be test fitted before shipping, and guaranteed to fit perfectly. could paint and clearcoat for extra, depending on color.
Car: 1984 T/A
Engine: LQ4
Re: interested in 91/92 rocker fiberglass ground effects??
just wondering how are you making the gfx off of yours?
Transmission: Pro-built 700R4
Do you already have a set fabbed up? Not knockin' you, but nobody knows your skill level enough to fork out $200 bones sight unseen. If you had a example of your workmanship I think you would have a better shot and selling them. Not a bad idea though.
Car: 87 formula
Engine: 350tpi
make a mold, using everything necessary to make them right, without taking any shortcuts.. have seen waaay to many ebay kits that are unbelievably cheap quality, warped and dont even come gelcoated...
Car: 87 formula
Engine: 350tpi
blacksunshine'91: true, sadly i dont have any pics of my fiberglass projects
I will take pics and post them when I start on them monday.. I just wanted to see if I had a couple people thatd be interested in something like this before I spend money on materials.. wouldnt mind now, thinking itd be a fun project to work on and have spare set..
I will take pics and post them when I start on them monday.. I just wanted to see if I had a couple people thatd be interested in something like this before I spend money on materials.. wouldnt mind now, thinking itd be a fun project to work on and have spare set.. Supreme Member
Car: '91 TA vert
Engine: turboLSx
I hope I don't offend but I would not be interested in fiberglass version. Even the factory style are too fragile, IMO. An even stiffer, more brittle variant would scare me. Just my $.02
There was a member talking about offering metal replacements and even that scared me a bit. I guess luckily he never came through and I eventually found a set of factory versions.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
vfn already makes these, however i dont know how they mount
now are we talking about the rocker pieces, that go under the doors, or what?
Car: 86 Trans Am
i remember the metal pieces somebody was going got do to replace the front fender gfx, they were not even remotely close to what the real piece was.
Car: '91 TA vert
Engine: turboLSx
Car: 86 Trans Am
this thread says, rocker, so i assumed under the doors, not the fender GFX. Seems odd, but ok.
If this was for front fender gfx, there is no way to make the from glass for 200 bux, way to intricate. But at least if they get busted, they are easily fixed.
Hawks has re-pop front GFX made fomr ABS. Not sure how they hold up strength wise
Car: 87 formula
Engine: 350tpi
Car: 87 formula
Engine: 350tpi
yeah, i was talking about the ones that go under the bottom of the door, not on the door nor the front ones..
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
Thomas
Oct 3, 2015 05:34 PM
92firebirdchris
Aug 14, 2015 11:56 AM
