Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
could a tpi intake be cut down?
Old Apr 10, 2012 | 09:01 PM
project89's Avatar
i have an idea for a new project but i was wondering could a tpi intake be cut down to work on a 4.3v6 like the stealth ram is cut down to fit the 4.3?
Old Apr 11, 2012 | 02:51 AM
project89's Avatar
Re: could a tpi intake be cut down?
incase anyone is wondering what im talking about heres some pics
Old Apr 12, 2012 | 06:57 AM
SCCAjunkie's Avatar
Car: 84 Z28
Engine: 91 L98 long block with Pro-jection
Axle/Gears: 91 10bolt w/ 3.42s and T2R
I'm confused as to how still have 8 ports will work feeding a 6... Obviously it's not done yet.
That said, the runners on the stock TPI don't drop straight down, they cross, and also go through the center section where that manifold was shortened. I'm not saying it's not possible, but it's probably not going to be a cut-and-paste procedure.
Old Apr 12, 2012 | 06:08 PM
project89's Avatar
u are right i didnt post the finished pictures,what is done is they block off 2 of the runners on the top of the manifold
Old Apr 13, 2012 | 07:45 PM
ex-x-fire's Avatar
Grumpy Jenkins used to cut up sbc intakes to work on chevy 90*v6s. He used a tunnelram, but a tpi is possible, aluminum is easily welded. You need to figure out how to cut it so the ports line up. I think grumpy staggered the cuts.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
masonta
Aug 31, 2015 10:14 PM
Sanjay
Aug 12, 2015 03:41 PM
