Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
roll bar welding question
Old Apr 15, 2012 | 02:26 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
Axle/Gears: 10 Bolt 3.42
I am in the process of welding in a simple four point roll bar into my 92, and the rear bars that come down from the main hoop are set to be welded in on the flat hatch section immediately behind the rear seats..
now i now this section is above the gas tank, so i was a little worried about welding them in with the tank in the car.
however, i also noticed that there are spot welds in the same section so i assume that it is a little thicker sheet metal..
overall i just want to know if people have welded this area without any problems, or if the sheet metal is thicker there...
thanks
Old Apr 15, 2012 | 02:35 PM
Twin_Turbo's Avatar
Re: roll bar welding question
if you want to do a qualty job, fabricate some base plates, weld those on first and then weld the bars on there, no sense in welding bars to thin sheet metal without spreading the load, the bars will poke right through when you need them the most
Old Apr 15, 2012 | 03:41 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
i have base plates, and i plan on welding the bars to them, i'm wondering about welding the plates to the sheet metal of the hatch area.
Old Apr 15, 2012 | 03:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The best spot is right behind the shock mounts. that's where the frame is and the strongest part of that area
Old Apr 16, 2012 | 09:44 AM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
okay, the roll bar is already made and the hoop is welded in, the rear bars come down right behind the rear seats, i don't want to hack it all up again, so i'm just wondering if anyone can tell me if the sheet metal there is thick enough that i shouldn't have to worry about having embers falling on to the gas tank, or if i would have remove the tank first...
Old Apr 17, 2012 | 10:53 PM
1gary's Avatar
Well,how's your supply of Kevlar suits??.
Old Apr 19, 2012 | 10:40 PM
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
what the ****, thats really helpful.....
Old Apr 19, 2012 | 10:51 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
He means.....Pull your tank, then weld your plates in.
Old Apr 19, 2012 | 11:57 PM
irocarter's Avatar
Car: 89 iroc
Engine: 5.7 trick flow heads t-ram
Transmission: wct5
When I put my down bars and plates in, I did not pull the tank but I did take my time welding the plates in to make sure the area didn't get too hot.
Old Apr 28, 2012 | 11:59 PM
3ZMan's Avatar
Remove the tank, it's not worth the risk. It's a PITA to remove the tank but it's the sure way to keep the car/house/garage safe. I've done two (8-point roll bars) - and have removed the tank both times.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
