Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Fuel lines for an 86 TPI
Old Jul 12, 2012 | 06:41 PM
86irocIrock's Avatar
Car: 86 Iroc-Z
building an 86 iroc i picked up for cheeeeep...needs the majority of the fuel lines replaced, buuut im having trouble locating the lines from any and pretty much all sources. does anyone know of places that custom make fuel lines that will bolt right up like a factory replacement? id rather have a tight factory fitting on the pressurized fuel lines then a repair kit...any input is greatly appreciated. thanks!
Old Jul 13, 2012 | 11:18 AM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: Fuel lines for an 86 TPI
PM Sent, There company is not site sponsor.
Old Jul 13, 2012 | 04:14 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
So what? What's the company?
-- Joe
Old Jul 13, 2012 | 10:20 PM
Car: 86 Iroc-Z
inlinetube.com , i just ordered a set of brand new factory matching fuel lines , a set of 3 supply lines for $119+ shipping. i called and asked if they had a diagram of the set to verify the line i needed was included but they didnt have one but the guy assured me the line that runs from the fuel tank to the fuel filter was included...so fingers crossed and i hope this is a good find.. if soo this would be a lifesaverr...ill keep ya posted on the lines when the come in...expecting them by wednesday
Old Jul 14, 2012 | 06:10 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Good deal.
We don't allow non-supporting vendors to push their products, however members are encouraged to talk about vendors and share information, regardless of supporting status.
I cut my hard lines at the sender, and flared it to attach a -6 AN hose. I run about a foot or two of braided into a summit high pressure filter. Then I attach to the factory hard line to run between the axle and engine bay, where I turn into -6AN braided again.
-- Joe
Old Dec 15, 2012 | 12:40 PM
galletti's Avatar
Car: 1988 IROC Convertible
Hi Anesthes,
I'm looking to replace ALL my fuel lines with -6AN but I'm having a hard time figuring out how to go from the sender nipple/flare to -6AN. I see you say you flared yours. Can you give me some details as to what kind of flare you used and what adapter to -6AN. Also, I'm looking for suggestion on what inline filter to use, specifically, what micron size. Any information will be greatly appreciated. Thanks.
Old Dec 15, 2012 | 01:23 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally Posted by galletti
Hi Anesthes,
Just so you know, I'm redoing this. The -6AN is fine but where it snakes past the headers was making me nervous. I don't know how much heat is required to melt braided fuel hose but..
So anyway, out of the sender where the factory nuts are cut and flared it with a double flare. You can do a 37* flare and use AN tube nuts, or a 45* flare and use an adapter. You need a double flaring tool because the OEM fuel line will crack on the seam when you tighten it, so it may be better to use a 45* tool since they are cheaper and just use a -6 to 3/8 adapter.
For the filter, I used a Russel 650133 which is 40 micron, and -6 in and out. So I made a small braided hose between the hard line at the tank and the filter, then I come out of the filter with hard line and don't transition back to braided hose until I'm by the brake booster.
-- Joe
Old Dec 15, 2012 | 02:02 PM
galletti's Avatar
Cool! Thanks for the detailed information. I have a 45* I used before for my brake lines. I actually think I have the adapter because my original plan was to use the factory lines into the engine bay and then convert to AN into a remote mount AFPR but I might as well do the whole thing. I'm also doing the return. Thanks again for the information.
Old Feb 22, 2013 | 07:00 AM
galletti's Avatar
(months later...) I have one more question I ran into if you don't mind. What pressure are the tube nuts rated to? I read somewhere they only go to 40-50 psi. I'm running a tpi fuel injected setup and my fuel pressure will be above that. Thanks again.
Old Feb 22, 2013 | 07:06 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The "compression" tube nuts that go on a 3/8" hard line and make it a -6 or whatever are only rated to 40psi. They are not approved for EFI.
Like I said earlier, I double flared mine and used a 3/8 to -6 fitting.
You could pick up a 37* flaring kit, and double flare it as well if you want to skip the adapter, and use a male-male -6 fitting. These are FLARED tube nuts, which are not the same as the compression style ones the carb guys use. They will be a tube nut and sleeve.
-- Joe
Old Feb 22, 2013 | 05:27 PM
galletti's Avatar
Thanks for coming to my rescue again. So, to clear it up, if I used the tube nut with the "crush sleeve" (I guess you could call it) then it's only rated for 40 psi. However, If I double flare and join, (I hereby relieve you of ANY responsibility for ANY repercussions that may arise if I do this) then I should be OK.
Old Feb 22, 2013 | 05:50 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
No.. We're not talking about crush sleeves when we're talking about flaring. Those are compression fittings.
-- Joe
Old Feb 22, 2013 | 09:07 PM
galletti's Avatar
Halelujah...holy crap!!! I finally got it! (This is what lack of sleep because of 4 month old twins and a very sick 12 year old dog will do to your though processes.) Anyhow, I mixed up the genders of the tube nut and the compression fitting and it wasn't making sense. Am I correct in saying that, doing a double 37 degree flare with the correct tube nut, that it actually becomes a -6AN female end?
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
