Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Harness bar ?s
Old Nov 26, 2012 | 10:20 PM
85irocz8j's Avatar
Harness bar ?s
I want to put 4 point harness's in my 85 iroc because I do some dragracing and track days with it. But I was wondering if it is possible to make one or buy one that would still make the rear seats usable. Can the bar be easily removable but still safe?
Old Nov 28, 2012 | 01:51 PM
Brad96's Avatar
Car: '07 Cadillac CTS-V
Engine: LS2
Re: Harness bar ?s
I can't think of any way to install a harness bar that would be strong enough to do the job, without rendering the rear seat useless, or at least unsafe. If you want to keep the rear seats, then an "easily removable" bar might be a better goal.
Toward that end, I created a fully bolt-in harness bar for my '88, using the stock rear seat belt mounting points: https://www.thirdgen.org/forums/fabr...rness-bar.html The weaknesses of my design are discussed in the thread.
A better mounting location would be in the area of the rear upper shock mounts. Since your '85 and my '88 don't have back seat shoulder harnesses, you would have to weld something in place. It wouldn't be a true "bolt-on", but you could make it easily removable, to convert between track day use and family hauler duty.
FWIW, I recommend using 5-point harnesses. It's not hard to add a mount for the crotch strap.
Old Nov 28, 2012 | 04:46 PM
85irocz8j's Avatar
Re: Harness bar ?s
Would it be possible to use a 3 point harness and mount it where the stock retractor goes in the roof?
Old Nov 28, 2012 | 05:07 PM
Brad96's Avatar
Engine: LS2
Re: Harness bar ?s
I'm not familiar with a "three-point harness". Wouldn't that be like a stock seat belt?
Old Nov 29, 2012 | 07:16 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
Re: Harness bar ?s
I am looking at doing something similar with a 3 point harness.
Brad, the 3 point harness uses the same dual shoulder setup as a 4 point, but instead of the shoulders being 2 separate straps they go to one retractable strap that works with an inertia lock.
I don't want the hassle of a cage, or even a harness bar in my car, but I love that harness look. My Camaro has never seen a strip and most likely wont so I'm not overly concerned about it being to those standards. I have been searching for a way to use a 3 point with the original shoulder strap but with no luck yet.
Old Nov 30, 2012 | 02:00 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Harness bar ?s
unless you are going to put a proper roll bar in with a harness bar at hte right height on it, just stay with the stock belts. you can get aftermarket harnesses that are long enough to use the rear seatbelt mounting points for the shoulder belts, but then you are relying on the stock seat to not cave in under the pressure of the belts and break your collar bones, and the belts stretch a certain percentage of the length of the belt, so a belt that's got an extra 3 feet of length to get to the mounting points might stretch enough to allow your face to become one with the windshield in a frontal collision, which kind of defeats the whole purpose of a "safety" harness.
Old Dec 3, 2012 | 10:44 AM
Brad96's Avatar
Engine: LS2
Re: Harness bar ?s
Dabesiv,
OK, I looked them up, and I see what you're saying. But, the factory shoulder harness mount point is not centered behind each seat. It's offset toward the outside. I think the attachment point that supports both shoulder harnesses in that 3-pt setup needs to be in the center, or you risk imparting nasty crash stresses into your neck.
Old Dec 3, 2012 | 12:32 PM
Dabesiv's Avatar
Re: Harness bar ?s
Originally Posted by Brad96
Dabesiv,
I was thinking the same thing, Just hoping for a better idea. I love having a back seat so I won't do a cage, and I think a new inertia lock for a 3 point would take some of that space up too. oh well
J-money
Jan 4, 2019 09:45 AM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
87camaro87
Sep 9, 2015 10:29 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
Billy Decker
Sep 4, 2015 03:46 PM
