Help with stock 7.5 axels
I decided not to build a 9inch for my 85 dirt track car, and I want to get better aftermarket axels.Where should I go for the best deal? I don't want to spend much. Thanks. The rearend had 3:73's out of a 86 transam if it makes a difference.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Help with stock 7.5 axels
The cost of aftermarket 26 or 28 spline axles is the same. Since you're going to upgrade, you might as well upgrade the posi as well and go right to 28 splines.
You can get axles from just about anywhere that makes axles. Back when I had a 10 bolt, I used axles from here. I bought their KA axles.
http://www.tomsdifferentials.com/
26 spline is KA7-A5
28 spline is KA7-A7
I don't know what the going rate is. When I bought mine, they were only $125 each.
26 spline is KA7-A5
28 spline is KA7-A7
hectre13
Dec 11, 2023 08:14 AM
ambainb
Apr 25, 2016 09:21 PM
toronto formula
Nov 10, 2015 06:17 AM
Genopsyde
Oct 7, 2015 08:35 PM
hectre13
Aug 26, 2015 08:17 AM
