Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Side view turn signal mirror install
Old Jan 5, 2013 | 10:27 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so beem seeing alot of newer cars with the side view mirror turn signal im wondering if anybody has put a set into there 3rd gens yet an if so how hard is it to do
Old Jan 5, 2013 | 10:50 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Side view turn signal mirror install
I've seen one with a light mounted inside the side mirror housing so that basically the light that was seen was what what shined around the mirror.
Then small LED strips mounted to bottom of the mirror housing.
And 1 guy that actually pulled the mirror & somehow made the orange arrow pattern appear through the glass. Dunno how he managed that one. Scrapped off just enough backing for it to shine through but still had a mirror reflection?
Old Jan 5, 2013 | 10:59 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Sounds pretty slick. I'd be interested.
Old Jan 6, 2013 | 12:34 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I have some bulbs mounted inside the light housing on a custom bracket. Just working out the wiring. Stay tuned and I should have a write up in the next week or two...
Old Jan 6, 2013 | 02:06 AM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I've been wanting todo this as well ...I shaved my doors ...I filled all the holes for handles, key hole, and the mirror's....I want to find a set of 4th gen mirrors with the light in them ...also because I shaved my front blinker in the fender...
Caspar
Jun 19, 2016 11:19 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
89FormulaMan
Aug 10, 2015 10:01 PM
Fronzizzle
Aug 9, 2015 01:15 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
