Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Any Ideas?
Old Jan 8, 2013 | 07:32 PM
Dskeezy16's Avatar
Car: 1985 Firebird Trans Am
Engine: ls1
Transmission: t56
Axle/Gears: 8.8 Ford 3:73's
Any Ideas?
I need some ideas on how to keep a nitrous switch plate in my ash tray from floating. It wont sit flat like I thought it would. The right side of it is being pushed up by the wires, that cause the lid not to close or open. I tried using a puddy to hold it down, that only worked for about 10 seconds. Anybody have an idea to hold it down and keep it easy to remove the plate?
Old Jan 8, 2013 | 08:49 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Re: Any Ideas?
Notch out where the wires are to allow them to sit lower. Otherwise build something that will allow you to pin it in place; IE- like how hood pins work.
Old Jan 8, 2013 | 09:36 PM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Any Ideas?
screw it down.
Old Feb 12, 2013 | 02:24 PM
wbstearns's Avatar
Car: 01 s10 blazer and 89 bird
Engine: 383 with mystery cam - maybe
Transmission: t56 hopefully
Axle/Gears: 373 geared posi from 2002 z28
Re: Any Ideas?
im assuming the wires stick straight out the back look at trying to change that configuration to some kind of an elbow and it might sit right i had similar issue with a head unit and antenna wire fought it for a month when a $6. part solved it
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
