Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Custom TBI CAI
Old Jan 27, 2013 | 11:22 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
Custom TBI CAI
Ok I recently made myself a custom CAI that looks really cool and does
It's job very well , which is to let the engine get the coldest air it can possibly get without restricting airflow ... Now this aint really the most cost effective thing u could do but like I said it looks really clean and does its job . So I'm going to tell u how to make it yourself and show you the final result ...
What u need : 1) carb hat 75-100$ (mine is 4" so I had to use a 4-3 reducer)
2) 5' of 3" aluminum Intake tubing ( 30$ @summit racing )
3) 1- 90* 3" Epdm rubber elbow (25$ @ summit racing)
4) coupling for carb hat to tubing connection ( 15$ @ summit )
5) air filter of your choice ( before ordering filter measure the
Distance between the top of the a-brace that hooks to the
Bottom of the driver side fender and the sheet metal under the
Charcoal canister , get a filter that will be as tight as possible
I had to force my brace back in but it helps hold the filter.
Ok now take out the ccp canister and relocate or dispose of ( ur choice ) also have to relocate or dispose of vacuum ball . Now cut a hole in sheet metal dead center where ccp canister was ( cut the hole so that the flange where the hose clamp on the filter goes will fit tightly in the hole so u can tighten hose clamp from the engine bay .. Next put ur carb hat on . Now put ur coupling on the carb hat and insert ur 5' piece of pipe into the hat as far in as it will go .. Now take ur 90* elbow and eyeball it with the hole u cut and mark ur tubing with a sharpie now go cut it ( grinder hacksaw sawzawl etc) ... Pipe cut ? Ok ur half way there ... Now clamp the reducer or coupling to the carb hat and insert the pipe u cut ( don't clamp it ! Now remember that A brace ? Take it off ... Now take the hose clamp off ur air filter and put filter I the hole from the bottom and put a brace back on to hold the filter in place ... Now put the 90* elbow on the pipe u cut ... Now measure from the inside of the filter to the inside lip of the elbow .. Cut it ... Assemble ... Done ...
Ok so here some results ... I have Robb's ebl flash so I can see my IAT values ... Before this setup on a 50* day I was getting IAT values of over 100* now on a 50* day I'm seeing temps of about 54* ... And a 3" CAI moves just as much air as my 3" exhaust so seems right to me ... Here's a couple pics ... Let me know what y'all think ! Sorry if my instructions suck ... Pics should tell all
Old Jan 27, 2013 | 11:26 PM
Car: 1991 firebird
Axle/Gears: 4.10
Re: Custom TBI CAI
Filter
Old Jan 27, 2013 | 11:41 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Custom TBI CAI
Coulda hooked it up to a TPI filter assembly like......
Old Jan 28, 2013 | 12:04 AM
Car: 1991 firebird
Axle/Gears: 4.10
Re: Custom TBI CAI
[QUOTE=BlackenedBird;5475151]Coulda hooked it up to a TPI filter assembly like......
Yea I coulda .. That's cool and effective as well .. I just tend to do things different and with my own little touch ya know
Old Jan 28, 2013 | 10:32 AM
Trav97z's Avatar
Re: Custom TBI CAI
Well done. Its clean and doesn't look like some garage hack job. Also some impressive results!
Old Jan 28, 2013 | 11:06 AM
Car: 1991 firebird
Axle/Gears: 4.10
Re: Custom TBI CAI
Thanks man .. I like it .. Also anyone interested in doing something like this should note than anything bigger than 3" won't work unless U get some different angled boots and Route Around the alternator
Old Feb 1, 2013 | 02:22 PM
morgsie's Avatar
Re: Custom TBI CAI
Where is the filter? Is it attached under where the carcoal can use to be? p/n?
Old Feb 1, 2013 | 08:02 PM
Car: 1991 firebird
Axle/Gears: 4.10
Re: Custom TBI CAI
Yes it is ..
Old Feb 2, 2013 | 01:42 PM
ChrisC's Avatar
Car: 1983 Z28/2000 ZR2
Engine: CFI to carbed 305/ 4.3
Transmission: Built 700r4/4L60e
Axle/Gears: 3:23/3:73
Re: Custom TBI CAI
Where'd you get that carb hat/who makes it?
Old Feb 2, 2013 | 03:05 PM
Car: 1991 firebird
Axle/Gears: 4.10
Re: Custom TBI CAI
Spectre from summit racing (100$).. If I were to do it again I would buy one that is deeper to u can remove the gold spacer ring from the TB
Old Feb 2, 2013 | 08:36 PM
3rdgenkiller's Avatar
Re: Custom TBI CAI
Did you consider drilling hole in the firewall so you could pick up air at the high pressure area of the windshield? I am consider doing that for my camaro.
Old Feb 3, 2013 | 08:16 PM
Car: 1991 firebird
Axle/Gears: 4.10
Re: Custom TBI CAI
Yea I considered about every way I could do it and this appealed to me more than anything else .. And like I said my IAT temps are only about 5* above amount temp settin still .. It don't get much better than that
Old Sep 4, 2013 | 08:14 AM
Car: 1991 firebird
Axle/Gears: 4.10
Re: Custom TBI CAI
Bump for newbs
92firebirdguy
Sep 1, 2016 07:53 AM
92rsvortec350
Sep 10, 2015 10:54 AM
Ranbo108
Sep 9, 2015 12:20 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Billy Decker
Sep 4, 2015 03:46 PM
