Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Strut Tower Brace for a strange set up
Old Apr 19, 2013 | 11:53 PM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
I want a strut tower brace but my cold air intake gets in the way of most aftermarket ones. Any ideas?
this is my set up
Old Apr 20, 2013 | 07:34 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Strut Tower Brace for a strange set up
i have a similar set up on my car . i have an edelbrock TPI cross bar with custom made braces back to firewall . they are needed to access aircleaner lid . if you have any fabrication skills it should easy . good luck .
Old Apr 20, 2013 | 07:58 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
make your own custom one.
Old Apr 25, 2013 | 05:22 PM
Engine: 5.0 L03 V8
That's a good idea. How do you have it fastened to the strut towers though? could I see more pics please?
Old Apr 25, 2013 | 06:44 PM
project89's Avatar
this is my set up
i would remove the side snorkle completly the tpi airbox will feed more air then u need alone
this will clean up the engine bay and give u a lil more room to work with on the driver side
Old Apr 25, 2013 | 08:00 PM
Engine: 5.0 L03 V8
I dont know I like having the additional snorkel, I've even considered adding one on the passenger side.
Old Apr 26, 2013 | 04:44 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
not the best pics. i originally made it for tpi, but when i switched to carb, i cut it apart. i should re-make it,...kinda ugly, lol. its made from some angle, some adjustable rods from a go-cart steering, some shock extensions, and a pre-bent bar that came out of the wifes mini-van rear seat, lol. anyway, might give you some ideas?
Old Apr 26, 2013 | 04:56 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
here it was as tpi.
Old Apr 26, 2013 | 06:26 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I had to make my own also, probably the best advice.
Old Apr 26, 2013 | 12:13 PM
Engine: 5.0 L03 V8
Redneckjoe thanks for all the pics that gives me a better idea of it. Ed I figured I would have to make my own just was looking for others had tried, since you also made yours you could post a pic
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
red90IROCls1
Aug 25, 2015 06:56 AM
