Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
can i use a xdp fuel sump for a gravity feed fuel system
Old Aug 18, 2013 | 02:22 PM
90firebird350's Avatar
Car: 1990 formula 350
Engine: 383 stroker
I was looking at the edelbrock e street efi return style setup but it said that you need to gravity feed to the fuel pump and I don't want to do a weld on fuel sump for it because of time and money and my lack of welding skills. so I did a little research on fuel sumps and was looking at a xdp non drop out fuel sump that diesel truck run. please somebody let me know if this product will somewhat fit my needs for the gravity feed fuel system here is a link to the xdp fuel sump http://www.xtremediesel.com/xdpblack...opinstall.aspx
Old Aug 19, 2013 | 08:37 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: can i use a xdp fuel sump for a gravity feed fuel system
The only problem i see with that is it only has one outlet.
That would only be an issue if you are running a dedicated nitrous fuel system.
Otherwise i like it..................just be sure to put it at the lowest hanging point of the tank rather than in the middle like they show on their site.
Old Aug 20, 2013 | 12:11 PM
83 Crossfire TA's Avatar
No reason that you couldn't drill/tap a second hole in it if you needed it. I like the idea, but you still need access to the top of the tank to get the reinforcement "horseshoe" in.
Old Aug 21, 2013 | 08:54 AM
Engine: 383 stroker
ok sweet so I should be good because im not running nitrous. thank you
Old Aug 21, 2013 | 08:59 AM
Engine: 383 stroker
ive got access to the top but you don't need to with this because of the horse shoe design.
Old Aug 21, 2013 | 11:34 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
The reinforcement is designed as a horseshoe so that it can be insalled through th same hole you drilled for the sump............thats why they say no need to drop tank.
Just slip the opening of horseshoe on tank edge and roll it into the tank.........thats why i like it....
You just gotta be VERY careful to get ALL shavings from the hole saw out of the tank..
ShopVac and a good magnet..............
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
