Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
shoehorn sbc and t-56
Old Feb 2, 2014 | 07:28 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Just wanted to see if anyone here has done this. I am taking my entire car apart and thought it might save time of I don't have to take the tranny of the motor.
Old Feb 2, 2014 | 08:40 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: shoehorn sbc and t-56
Yes, I have done it, with the distributer cap on. I had to take the radiator out, and have one person under the car [on a lift] pushing the tail of the transmission down.
I'm not sure it could be don't on jackstands, the transmission has to point over 45* down
Old Feb 5, 2014 | 02:28 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I recommend taking the distributor off, and anything on the top of the motor (carb, air cleaner, etc). But yes, it's totally possible (that's how mine went in, was motor+tranny).
Old Feb 5, 2014 | 02:33 PM
Car: 1983 Z28
Also helps if you take the fan off (if it's mechanical) and remove the radiator
Old Feb 5, 2014 | 05:39 PM
Twin_Turbo's Avatar
Since you are taking it all apart, install the engine + trans + front subframe from below, easiest way to do it.
Old Feb 7, 2014 | 05:12 AM
Engine: LS3
I will be ready to pull the motor and all in a week or so. Dizzy will be off, radiator will be out, no fans, but the car is just on jack stands. I will post some pics and you guys can give your final verdict
Old Feb 8, 2014 | 09:59 PM
Pocket's Avatar
Car: 91 Trans Am
Done that several times. Fastest without any excess difficulty
Old Feb 9, 2014 | 08:07 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i leave the bellhousing on and undo the 6 or 8 bolts that hold the housing to the gear box and remove it that way
Old Feb 9, 2014 | 01:54 PM
Engine: LS3
That's how I have done it in the past as well.
Old Feb 15, 2014 | 05:49 AM
Engine: LS3
I have to drain the tranny right? I think I have a vague memory of tranny fluid spilling out the tail shaft last time I talked it a lot, like to shoe it in
Old Feb 15, 2014 | 09:03 AM
Pocket's Avatar
Car: 91 Trans Am
Got an extra slip yoke? Stuff it in the tail or drain the fluid
Old Feb 15, 2014 | 10:06 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Just make sure you secure the slip yoke
I forgot this step first time I pulled mine and it fell out, making a big mess.
Old Feb 15, 2014 | 11:44 AM
tom86iroc's Avatar
Car: 1986 iroc
we have an extra slip yoke so we don't have a mess that's it and as long as u don't turn the tranny over it'll come out from the shifter spot
Old Feb 15, 2014 | 05:31 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
I put the rear of the car on ramps then set a skateboard or a moving dolly under the car for the tailshaft to sit on on so it doesn't scrape the floor
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
Damon
Sep 26, 2015 04:29 PM
