Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Hood prop rod
Old Mar 24, 2014 | 08:23 PM
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: T-56 w/hurst short throw
Axle/Gears: unknown
Hood prop rod
Has anyone bolted a hood prop rod on their car instead of buying hood struts? It's not the priciest item(s) I need fixed but you just can't beat the stick. I am curious to the optimum length it needs to be and which vehicles will have them from the junkyards.
This is also useful in case I buy a fiberglass hood for my Camaro; I would need a new set of hood struts.
Old Mar 25, 2014 | 08:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Hood prop rod
I still use the struts to hold my fiberglass hood up. Sticks and props just get in the way when you're working on the engine.
Old Mar 25, 2014 | 08:59 PM
datraum's Avatar
Car: 91 Camaro RS
Engine: 383ci, Holley 750cfm carb
Re: Hood prop rod
I also use struts on my fiberglass hood, but I went to the junkyard and got a set that wouldn't hold up a steel hood and they work perfect with no risk of cracking the fiberglass
Old Mar 26, 2014 | 07:48 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Hood prop rod
same thing here. worn out struts work great for a 'glass hood.
Old Mar 26, 2014 | 08:56 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
Re: Hood prop rod
I'd be more worried about actually getting the hood up to put it on the rod...The stock hood is quite heavy.
Old Mar 26, 2014 | 11:24 AM
Gecz28's Avatar
Car: 88 iroc vert
Re: Hood prop rod
i thought about something like this
http://www.ebay.com/itm/NASCAR-ALUMINUM-HOOD-DECK-LID-HINGE-SET-X-2-FREE-SHIPPING-IN-U-S-/380823488618?pt=Race_Car_Parts&hash=item58aad9486a&vxp=mtr
Old Apr 1, 2014 | 06:15 AM
Homer23's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: unknown
Re: Hood prop rod
That's not a bad idea if you want a cool looking one. But if blown hood struts will hold up a fiberglass hood, I may keep my blown ones for when I get a fiberglass hood. But, you would get used to the stick in that one small spot.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
corey8084
Sep 17, 2015 02:56 PM
TOMcat GTA
Sep 15, 2015 09:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
