Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
cut floors for sfc's
Old Nov 8, 2013 | 06:54 AM
Gecz28's Avatar
Car: 88 iroc vert
hey guys, was wondering if anyone thought about cutting their floors to install sfcs? i see people talking about their sfcs scrapping. i wonder if its worth it to have sfcs straight instead of bent or angled? just use one piece of square tubing to connect everything???
i havent looked under my car/project in some time, so im not sure if cutting the floor would interfere with seats/bolts, foot room or anything else??
opinions/thought???
Old Nov 8, 2013 | 08:56 AM
Pocket's Avatar
Car: 91 Trans Am
Re: cut floors for sfc's
Why not get a better set of SFCs?
In almost all cars the exhaust is the lowest point
Old Nov 8, 2013 | 09:02 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
My UMI SFCs don't scrape. They are higher than my exhaust
Old Nov 8, 2013 | 09:17 AM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I've only heard of the inners scraping. Outer/perimeter style is a non issue when it comes to ground clearance.
Cutting the floor is an extremely poor idea. Especially when your trying to increase stiffness.
Old Nov 8, 2013 | 09:59 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
I used the JEGSTER subframes in my TA in avitar she was lowered 1.5" and never touched the subframe connectors.
Old Nov 8, 2013 | 10:40 AM
nosajwols's Avatar
Car: 82 Z28
Transmission: TH350 for now
I made my own (outer) and the ground effects and exhaust both hang lower. If they are outer and scraping they are either crap or not mounted right.
Inner I have no idea.
Old Nov 8, 2013 | 05:40 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
my alstons scrape often.it doesn't really bother me since i doubt its hurting them but it means i can't lower the car.
Old Nov 8, 2013 | 07:42 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Don't be scared!! Lol. I plan on doing that with my connectors for exhaust clearance and/or whatever else I throw at it. Just need to spend time on layout and planning. Are you putting a cage in it as well?
Old Nov 8, 2013 | 07:58 PM
Gecz28's Avatar
Car: 88 iroc vert
no cage for me. i want to lower or do air ride.
i remember seeing on a tv show (gearz maybe) they put sfc's in and cut a notch through the floor then welded the floors back to the sfcs. so route going, that i dont think cutting the floor would effect stiffness, just maybe leg room ect?
Old Nov 9, 2013 | 01:59 PM
myroc86's Avatar
Car: 86 Camaro
Engine: 350 LT1
Cutting the floor for this job would be no different than cutting them to weld new pans in. You could tack up some bracing if you really wanted to. Welding the rails in though is a different story. You'll need to either get elephant stands or place jack stands so the car is at ride height. It all depends on what material you use and how you place the rails if it will effect floor space or not. Like most guys say the perimeter style rails shouldn't effect ground clearance.
Posted from Thirdgen.org App for Android
Old Nov 9, 2013 | 02:18 PM
Gecz28's Avatar
Car: 88 iroc vert
the sfc ive seen the pass sides are bent, not straight. so saying if you were to take a straight piece of tubing and go from the front pass side rail to the rear rail and cut the floor where it touched?
Old Apr 1, 2014 | 06:42 AM
Gecz28's Avatar
Car: 88 iroc vert
this is what i was talking about
skip to about the 5:00 min mark
http://www.powerblocktv.com/episodes...eeper-wakes-up
ctoledo0834
Sep 18, 2015 04:16 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
machinist21
Sep 5, 2015 03:03 PM
mrdevontay
Sep 2, 2015 08:04 PM
