Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
my diffuser
Old Jun 3, 2015 | 12:19 PM
  #51
Abubaca's Avatar
Re: my diffuser
While I agree with your pictures, and your ideas about airflow, smooth edges, the flaps on the Nascar roofs, etc. etc. i think the issue is bang for the buck, risk vs. reward, noticeable improvements etc. etc. I think it's awesome that you or anyone else wants to fabricate a part that isn't available. Whether it works or not doesn't matter. That's what this hobby is all about. ....but all the examples you give are the .01% of the performance envelope. In the "average" situation, with your average hobbyist hotrod, I can't see it making a difference. At 200mph sure. Again, I save "average" situation. While I agree that all the small difference do add up, if it REALLY mattered, all thirdgenners would drive Firebirds and not Camaros, because technically they ARE more aerodynamic....in a lab you can see it, in the real world, you never will.
...but I'm 100% serious when I say that you should make it. I mean most the cars nowadays that DO have them don't make much of a difference either. The vette I think is the perfect example of having several race bred features that when pushed to the limit by an experienced driver, DO make a difference, but.....for 99.9 of the people that drive em, they never actually do anything.
Old Jun 3, 2015 | 01:20 PM
  #52
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
Re: my diffuser
Air pressure and air flow effect a vehicle at every speed. I see what you're saying about not really being effective unless you're at high speed, but honestly, I noticed the biggest improvement at regular highway speeds. If you were going faster, it was more difficult to tell what was happening, but I could notice a big difference in handling while changing lanes and in high winds and such in normal speed conditions.
Old Jun 6, 2015 | 02:03 AM
  #53
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: my diffuser
What was the angle and length of your diffuser?
Old Jun 6, 2015 | 02:53 AM
  #54
CatmanFS's Avatar
Car: 85 Z28
Engine: 93 LT1
Re: my diffuser
The flat pan surface was about 20" front to back, about 3' wide and sat at about an 8° angle up in the rear. Went from halfway on the muffler to the rear of the car, had a soft section between the muffler and back bumper, the little pic with the pink outline shows it well.
CatmanFS
Fabrication
184
May 18, 2023 09:34 PM
dennisschreuer
Fabrication
43
Jan 28, 2022 03:59 PM
5.OTRANSAM
Jan 22, 2015 01:08 PM
strc09
Fabrication
46
Dec 10, 2013 10:46 AM
Mr. McGuire
Oct 26, 2012 08:26 AM
