Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
tubular front end
Old Dec 9, 2015 | 02:51 AM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
tubular front end
Has anyone made a tubular front end that eliminates the fender wells I like the look of a open engine bay ant one done this or has build pics of it
Old Dec 9, 2015 | 06:23 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: tubular front end
Everyone and their grandmother sells them for 1st and 2nd gens, 64-70 mustangs, etc. I've not seen one for a thirdgen.
If you were to do one, I'd probably suggest fabricating it so it could take 4th gen spindles/rack/etc.
-- Joe
Old Dec 9, 2015 | 12:52 PM
Engine: sbc 350
-- Joe
Ya imight have to do some research see if I can see what it'll take to fab it up
Old Dec 9, 2015 | 08:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With the complete unibody design of the third gen, a tubular front end needs to be a custom fabrication. Chop everything off forward of the firewall and start fabricating. You would need to completely change the front suspension with something from the aftermarket. By the time you're done, it will be cheaper to make a tube chassis car.
The strut front suspension and inner fender design to hold the struts makes a simple tubular front end design difficult compared to first and second gens which have a simple bolt on front subframe that everything attaches to.
You can make a tubular framework to attach and hold the top of the struts just so you can remove the minimal metal from the inner fenders. You would also need to fabricate a removable front end (nose and fenders) to make engine access easier. There are complete fiberglass front ends available but they're more designed for track use only.
The front frame rails which hold the sheet metal, engine and suspension are all part of the unibody car. To simply cut them off and replace with tubes means a lot of design work. Attaching it to the rest of the body to maintain strength really means you need a cage in the car to add the rigidity required. Like I said, by the time you're done, a tube chassis car would be easier.
Old Dec 10, 2015 | 08:27 AM
lonewolf583's Avatar
Car: 10 Camaro SS
Engine: Stock LS3
Transmission: TR6060
Axle/Gears: Factory LSD 3.45
I've not seen a kit/product for front halving a thirdgen, but several on this forum have examples of completed inner fender deletes while retaining the stock unibody framerail. It's fairly straightforward fab job but the geometry of the surrounding area makes it a bit tricky technically to do it right. Coilovers only complicate the situation as you'll need to design tons of margin in the system.
If you're doing this for purely aesthetic reasons and have the fab skills, go for it. But functionally you're probably better off leaving them be. The amount of dirt, road-grime, rocks etc, that the inner fenders catch is substantial. Don't mean to be a buzz-kill, but that's the reality of it.
Old Dec 10, 2015 | 08:51 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Classic mustangs (64-70) are the same unibody as a thirdgen, and there are tons of kits available. Seems like the same effort to do a thirdgen.
Here is what a classic mustang front section looks like with fenders off:
You still have to cut it off at the top and bottom, weld plates to the top as attachment points, etc.
-- Joe
Old Dec 10, 2015 | 02:12 PM
Engine: sbc 350
ya im kinda looking to delete just the fender wells and making mounts for the struts i saw a guy on here making a flip up front end his was tubular but i can't find it again for pics
Old Dec 10, 2015 | 07:08 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You need to go a long way back to find that thread. I think the actual pictures that were posted were linked to a different site.
Here is a thread with pics you may be interested in
https://www.thirdgen.org/forums/fabr...front-end.html
Old Dec 13, 2015 | 06:50 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I think his whole car is caged and he does all his own work or has friends that own shops that can do something small for him. If it's the guy I'm thinking of, look at his garage and you will see he is on a different level than 95% of the members on here.
If you just want a tubular front end because it to make your front end look better just buy a tubular K member and A arms and then plate off the firewall, front trays and sides of the front trays. It's what I've been doing.
https://www.thirdgen.org/forums/memb...oming-aka.html
Old Dec 14, 2015 | 07:24 PM
83RDRACR's Avatar
Not a complete tubular front end as I kept the main frame rails. also I swapped in a 4th gen front suspension and moved the wheels 5" forward but the proces would be the same.
Plated firewall with 1/8 sheet for strength.
Old Jan 20, 2016 | 11:44 PM
PNYKILR's Avatar
Engine: twin turbo dart 406
If you cut the front end off and go tubular, its opening up an extreme can of worms!! Just way too much work. I had that brilliant idea a long time ago to do this and its still not out. I spiced into an aftermarket k member and kept my strut tower locations stock.
Old Jan 21, 2016 | 12:06 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
That looks great! And it also looks like a TON of work. Will be a super unique car when it is done.
Old Jan 21, 2016 | 06:44 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Like I've said, it's easier to just build a tube chassis car.
Old Jan 24, 2016 | 02:13 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Some Ive had saved for Years.
Old Jan 25, 2016 | 07:22 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
^^Whatever happened to that car?
Old Jan 28, 2016 | 11:35 AM
MeenZ28's Avatar
Car: 1992 Z28 Targa Top. Full air ride
Engine: 305 5.0 tpi v8
Transmission: A4
Axle/Gears: 3.73 gears posi
I've always wanted to do that ^^^^^^
Old Aug 17, 2017 | 08:49 PM
Regglok's Avatar
How did you attach the hood to the frame
ProtoMaster22
Exterior Parts Wanted
Aug 10, 2016 10:57 PM
GMan 3MT
Jul 23, 2016 10:39 PM
90formulaVortec
May 26, 2016 09:15 PM
aaron7
Dec 28, 2015 05:32 AM
JunJun
Dec 16, 2015 10:59 PM
