Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
3 Jaw self centering chuck
Old Jan 5, 2016 | 09:40 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
My sister bought me a self centering chuck for my small lathe. (3" chuck). I've never had one, I've always used a 4 jaw and spent 10 minutes with a dial indicator centering my work.
Anyway, I've got this thing mounted on the lathe and it has around .030" runout!
I looked at the spec sheet, and it showed an A dimension (outisde of chuck), and B dimension (face of chuck) and both showed .030" on the diagram. I'm assuming this means it's got .030" of runout and that's to spec. (HOLY SH!!
This seems like a lot to me. Like. Any thing I make that has to be centric (pulley, etc) wouldn't fly.
Any thoughts?
-- Joe
Old Jan 5, 2016 | 10:11 AM
LX_SS's Avatar
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
Re: 3 Jaw self centering chuck
Holy hell is right, that a metric **** ton of run out. 0.003 would be acceptable not 0.03 damn.
I'm guessing it uses a backing plate to mount not a set of cam bolts ?
Is it the same backing plate you use on the 4 jaw ?
Usually its the mounting of such that causes a big issue however if the spec sheet says its within tolerance, not sure how much better you will get it.
Anything you want super accurate as you said, 4 jaw and dial indicator is the way to go.
If it was purchased new from a store i'd return for a refund if its possible.
Old Jan 5, 2016 | 10:17 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It uses a backing plate adapter. It screws onto my lathe (1/2-20). The hub on the backing plate was about .020" larger, so I turned it down until it was just right. In theory, this should perfectly center the chuck, it's got a nice tight fit into the hub. Then 3 bolts to lock it down.
I'm just somewhat annoyed.
-- Joe
Old Jan 5, 2016 | 10:21 AM
LX_SS's Avatar
Engine: 347ci LS1
Could be possible the surfaces of the new backing plate adapter or the chuck. Even the mounting holes of the chuck to the backing plate not being perfectly aligned.
Other option is it could be in the jaws themselves.
I haven't done it personally, but i have heard of others doing very small machining on the jaw teeth that are out to help get it to run true.
Yeah i can certainly agree with how annoyed you would be feeling.
Old Jan 5, 2016 | 02:44 PM
Grant2k's Avatar
Car: 1992 RS
Engine: Iron 5.7 LS
Axle/Gears: 4th gen rear, 3:42s, Torsen
I was thinking that grinding the teeth would be the way to go, but then if you ever remove the chuck you'd have to redo it every time. Could you get more faceplates and remove the faceplate from the threaded spindle every time? Get the chuck right and have a faceplate for every chuck. That would be the most accurate solution. Or get a chuck that threads right onto the spindle.
Old Jan 5, 2016 | 03:07 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Faceplate?
-- Joe
Old Jan 6, 2016 | 07:11 AM
Grant2k's Avatar
Car: 1992 RS
Engine: Iron 5.7 LS
Originally Posted by anesthes
Faceplate?
-- Joe
Maybe faceplate is the wrong term, I'm not really familiar with small lathes like this. But I would guess the end of the spindle has a thread on it and on that thread is something like in the picture below. The most accurate, concentric, and repeatable way to mount and remount something on the spindle would be using those threads. If you can work it so that when you remove the chuck you are removing it right from the threads on the end of the spindle rather than with a pattern of bolts it would seem like you'd have less of a headache going between your 3 and 4 jaw chucks.
What I picture on the end of your spindle:
What your spindle probably looks like if you remove that plate:
Old Jan 6, 2016 | 09:29 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Oh yeah, called a hub adapter when I ordered it but maybe faceplate is right .
The adapter was screwed onto the lathe, and the hub turned until it was the same diameter as the register on the new chuck.
What I did NOT do was turn the face, so maybe I can take 10 thou off the face and see what happens.
My 4 jaw has it's own adapter/faceplate.
Here is a picture to the spec sheet though..
-- Joe
Old Jan 14, 2016 | 07:12 PM
RSD's Avatar
RSD
Car: 83 Z28
Engine: 355 SBC
Axle/Gears: 3.90
When checking runout, did you check at say an 1" from the chuck and then 3" from the chuck? I cannot imagine any chuck having a spec of 0.030 runout.
Old Jan 14, 2016 | 09:25 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The chuck itself is about .016", which is what the spec sheet says. (I posted the image).
When I put something in the chuck, about 4" out it's around .030".
When I put the same material in my 4 jaw chuck, I'm around .002-.003" runout...
-- Joe
TKO500
Interior Parts Wanted
Mar 15, 2016 11:25 PM
the_nikfive
Exterior Parts Wanted
Feb 1, 2016 02:52 PM
kanexpl
Jan 10, 2016 07:51 PM
fkboatman
Jan 9, 2016 04:58 PM
Irockthedrag
Dec 31, 2015 08:36 PM
