Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
'92 trans am locksmith advise
Old Mar 31, 2016 | 02:12 AM
marrythmas's Avatar
I heard the noise while driving home today. So, after I parked in my garage, I had a look at the trunk.. it appears to be locked.. but it keeps making the noise when I'm on the road. It feels like the lock is loose or something.. Should I call a locksmith?
Old Apr 1, 2016 | 12:29 PM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: '92 trans am locksmith advise
On my IROC there is only one sheet metal screw that holds the lock assembly to the tail panel. Maybe yours is getting loose? Located under the plastic panel and you can inspect it by removing just a couple of phillips screws.
However, it's probably the plastic pieces that hold the gear assembly in the pull down motor are breaking out and need to be replaced.
http://www.partsgeek.com/j757pf8-pon...ull+Down+Motor
Old Apr 4, 2016 | 01:14 AM
roryglenn8's Avatar
What he said and.. I doubt it, but if the lock itself is getting loose, then call a locksmith
Old Apr 4, 2016 | 10:31 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Open up the rear interior panel and take a look at the assembly. I'd be willing to bet that the guides are broken.
i88aGT
Apr 6, 2016 06:53 PM
ken3983
Mar 29, 2016 05:09 PM
Thirdgen89GTA
Mar 29, 2016 11:28 AM
'91CamaroRS
Mar 27, 2016 10:15 PM
Drone358
Mar 25, 2016 10:50 AM
