Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
4th gen windshield washer reservoir
Old Jun 26, 2016 | 10:09 PM
Boosted357's Avatar
Car: 1985 Camaro, 2012 Malibu LTZ
Engine: 357 SBC
Transmission: 350 Turbo
Hey guys i just picked up a 4th gen washer tank reservoir for my 3rd gen and the install seems pretty simple. The question i had is about the pump that is located on the 4th gen reservoir. I was wondering do i keep that mounted and run a longer hose to that pump or do i remove that pump and just run the hose inside the reservoir? If i do in fact use that pump how do i wire it. I havent looked to much at my stock reservoir but from what i recall there isnt a pump located on the stock tank, it just has the hose going into the cap and a hose pickup on the inside? Any clearification would be great. Thanks in advance
Old Jul 3, 2016 | 09:43 PM
Boosted357's Avatar
Engine: 357 SBC
Re: 4th gen windshield washer reservoir
Alright well i figured it out myself. I ended up removing the pump from the 4th gen tank and running a hose into where the pump was at. Everything is working great and it looks so much better then a big tank sitting on the fender.
Old Jul 9, 2016 | 10:21 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
The wheel arches really can look nice, removing the tanks is just the first step.
Old Aug 7, 2018 | 11:35 AM
Camaromac24's Avatar
Car: Camaro, Denali
Engine: 5.7
This is what i did for mine, i do agree it looks so much cleaner when they are not there.
https://youtu.be/Ju9B3ngJW7M
Old Feb 19, 2022 | 07:59 AM
bholmes's Avatar
When you guys remove the plastic air dam, did.you have any cooling issues!? Could you post/send pics of your install! I'm wanting to.do.as well!!TIA
Old Mar 8, 2022 | 10:55 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Most people have issues with their temps running higher without the front air dam, you may get more traction with this on the Cooling board?
Cooling - Third Generation F-Body Message Boards
ChristinaMarie
Camaros Wanted
Oct 24, 2017 12:47 AM
live4formula
Apr 21, 2016 07:21 PM
JustinLeonard
Interior Parts Wanted
Apr 1, 2016 09:41 AM
ChristinaMarie
Apr 1, 2016 07:02 AM
turd_gen
Exterior Parts Wanted
Mar 29, 2016 11:35 AM
