Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
subframe mod and y-pipe
Old Apr 5, 2017 | 03:44 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
My subframe mod for better clearence for 3" exhaust since the 4L80E is bigger then a th700 and to make a stiffer torque arm crossmember.
Made some scether before I started to cut
Made a temp solution for transmission crossmember ( and it may be permanet also...)
Driver side cut up
Pass. side.....
Cut the corner to make some more space...
test mounted pass side
Drivers side
Drivers side
Old Apr 5, 2017 | 03:45 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Re: subframe mod and y-pipe
Pass. side
Torque arm crossmember.....
Mounting check so it would be level to the ground
Drivers side welded...
Pass side welded
Torque arm cut, had to make it shorter....
Exhaust system, dual 3" to 3,5"
Muffler under the car can be replaced by straight pipe och catalytic convertor for emission test...
Old Apr 5, 2017 | 06:55 PM
makaveli09's Avatar
Engine: 350sbc
Transmission: TH700R4
Very nice. Great work on them frame rails. And exhaust as well.
Old Apr 6, 2017 | 12:30 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Wow nice job, very ballsy
Old Apr 6, 2017 | 03:10 PM
jbalzola's Avatar
Car: 1984 Pontiac Firebird
Engine: none atm
Axle/Gears: 3:73 zexel torsen
Mint!
Old Apr 7, 2017 | 05:12 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
thx!
Will se if I change to dual 3".
/N.
Old Apr 18, 2017 | 12:03 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
put some paint on it...
Old Apr 18, 2017 | 05:47 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Great job!
I wish I had those fab skills
Old Apr 18, 2017 | 06:33 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Similar to how I did mine but I wanted a bit more stock look so I just sectioned the stock frame rails. Nice work!
