Fabrication Custom fabrication ideas and concepts ranging from body kits, interior work, driveline tech, and much more.
Tube front end for a firebird
Old Jan 29, 2023 | 10:37 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Wondering if anyone with a firebird has made a tube front end for their car?
I know Rock Solid Motorsports makes one for a Camaro, but not a firebird.
They indicated to me that their kit will NOT work for a firebird, unless you make the flip lights not functionable.
Old Jan 29, 2023 | 11:10 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Tube front end for a firebird
Camaro and bird use the same factory sheetmetal framework.just cut and weld the aftermarket stuff to make things fit how u want?
Old Jan 30, 2023 | 08:21 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Quite possibly ya.
I'd like to see some pics of someone else that has did it before I cut the front end off, and realize it's too much work
Old Jan 30, 2023 | 08:41 AM
TTOP350's Avatar
Make no mistake, it's a ton of work
Old Jan 30, 2023 | 09:09 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Do you have any pics of your tube front end?
Old Jan 30, 2023 | 03:39 PM
DIGGLER's Avatar
i have the rock solid one on mine. huge amount of work. well, i say that mainly because i was wanting my foglights, headlights to function and be in the correct location, and all the body panels needed to line up as good as i was able. once you get the main tubing installed, you will realize just how much work is left to do, because in my opinion you arent even half way done at that point. lol
Old Jan 30, 2023 | 03:54 PM
DIGGLER's Avatar
i wound up shortening it a few inches, but this is the basic part that you build off of.
Old Jan 30, 2023 | 05:25 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Thanks @DIGGLER
That is the answer I was looking for!
I also want to retain the functionality of the lights in the front.
I got a buddy coming over this week to see if the whole deal is worth it
Old Jan 30, 2023 | 08:08 PM
DIGGLER's Avatar
headlight mounts
Old Jan 30, 2023 | 10:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
As much as I would love to have a tubular front end just to have more room under the hood, it's just too far out of my price range. I did the back half on my car and can easily see why just that could cost over $10k to complete. Front end would be even more. Looking at Digglers pictures, it's still not a full tubular front end. It's only been modified forward of the strut towers but still gives a huge amount of room. My BBC with Ed Quay headers would still have problems since it's still OEM behind the strut towers.
If you want to do a tubular front end and a back half on a third gen, it would be cheaper and easier to just build a tube chassis car,
Third gens are not a simple bolt in swap like first and second gens are.
Old Jan 30, 2023 | 11:58 PM
DIGGLER's Avatar
When people talk about tubular front ends now, this is what they are normally talking about. But you are correct, if my car was done behind the strut towers it would be a full tube chassis car. lol that is the only little bit of factory frame left, is the strut towers and down to the bottom of the firewall.
Old Feb 2, 2023 | 12:33 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why don't you guys cut the frame out completely and weld up body mounts to attach to a tube chassis ?
-- Joe
Old Feb 2, 2023 | 02:29 PM
DIGGLER's Avatar
-- Joe
In my case, i started out just wanting a 25.5 cage and that cascaded into a back half 4 link. and then 25.3. and then the tube front. was never intended to be a full tube chassis, and as it sits right now would be like an outlaw 10.5 car or what used to be, havent checked their rules lately. they maintained a stock front suspension at one point.
Old Feb 2, 2023 | 03:31 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
-- Joe
For me, I'm still a street car.
I'd like to do a drag and drive some day.
I'm not interested in a tube chassis.
It doesn't fit small tire classes either
Old Feb 2, 2023 | 04:46 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Makes sense.
You guys are way more competitive and faster than me. I'm pretty happy with a mid / low 11 second car.
-- Joe
Old Oct 13, 2024 | 02:58 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
Can you post more pics of this setup.
karl's-92'-z28
Members Firebirds
Apr 26, 2008 04:45 PM
85S10projectz28
Dec 7, 2007 08:25 AM
prOject-IrOc
South West Region
Feb 11, 2005 10:09 AM
