How to identify Camaros and Firebirds by year....
how to identify camaro/firebird year
assuming all emblems and decals are off, what are the easy ways of identifying the year of third gen camaros and firebirds. maybe quick ways of narrowing it down like 86 and up had third eyes.
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
Well, if they have stock tail lights, go around and look on the tail lights and it should say something like D.O.T. 87 and then some other stuff....the 87 would mean 1987.
My friends dad (former cop) also showed me on a newer camaro that i was wondering what year it was (looked absoloutly sick!) that on the vin plate.....
like the middle number between two letters is the last digit of the year or something like that but i have looked at other cars and either the number hasnt been there or its been a few years off from what i know it is....
the only year that stands out on it's own is the 86, it is the only year that came with the third brake light mounted on the outside of the glass up high near the roof, also the 86 is the first year that had the third brake light, so anything that doesn't have one is before that.
UNLESS SOMEONE HAS MODDED IT, which we all know doesn't happen to these cars
Car: 1987 GTA
Transmission: 4L60e
91-92 Camaro specific GFX
91-92 Firebird specific GFX
91-92 T/A specific Tails
1988 Mini-highrise camaro wing
1984 only Trans Am GFX
1982-1984 firebird specific Tails
1982-1984 Trans Am/ SE specific tails
I'm sure there are many many more. Guess your best bet would be to look under the hood at the emissions sticker. Should give you a good indication.
1 Post
Car: 85 IROC-Z
Engine: 406
Axle/Gears: 9" 411
You can tell from the VIN. The tenth digit of the VIN is the model year. here is an example 1G1AP87HXDN123456
now D means 1983
Model Year
D 1983
E 1984
F 1985
G 1986
H 1987
J 1988
K 1989
L 1990
M 1991
N 1992
now D means 1983
Model Year
D 1983
E 1984
F 1985
G 1986
H 1987
J 1988
K 1989
L 1990
M 1991
N 1992
The vin id is nice to have, but I was hoping for more "on the move identify" like the 86 third brake light. how about paint? were some colors only around for some of the years?
If you can look under the hood there are some giveaways. Serpentine belts indicate 1988 and up. TPI indicates 85 and up. MAP sesor instead of MAF sensor indicates 90 and up.
Spoilers are some what of a tell tale indication of model year. Flat TA spoiler any year firebird. The aerowing was only offered on 1985-1990. cars. The aerowing with the third brake light was used from 1987-1990. An aerowing with no brake light was used only in 1985 and 1986.
There are subtle ways you can identifiy the model year of these cars by looking at specific things if you really know your F-body options.
82-84 camaro has different fornt bumper cover and has slots in the front ground effect...
on the camaros you can look at the hoods too... if it has 2 scoop things in it that have no louvers and a more curved shape, its an 82-84 z28
if it has a more squared shape scoop things with louvers, its 85-90 iroc (i think 90) if it has blisters/scoops that stick on top of the hood and are solid its a 91-92 z28...
also the spoilers on camaros... if it has the high rise one, 91-92 z28
then the GFX... 82-84 are more squared on the bottom and not as tall,.... 85-90 are taller, and rouded on the bottom more... 91-92 have little scoops buy the back bottom of the door, and also in front of the front wheel....
fog lights = 85+ camaro
if its a convertible its 87 and up
wheels are another way to identify it, but youd have to get pictures...82-87 z28, then the RS's used the same with body color paint i think... 85-87 iroc had the same wheels 5 spoke with one groove down the center... then 88-90 iroc had the same wheels... 5 sppoke with 2 small grooves (lugnuts visible) and then 91 and 92 z28 had 2 grooves with the lug nuts covered by a little plate thing... i think those were also used on some of the rs's....
thats most of what i can tell you from what i know and have observed... all that is for camaros... i dont know my firebirds very good...
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
also just by glancing at the brake units....
i agree with speedingpenguin,but mine says D.O.T 89 not 87...so its not always a good way to tell
Car: 1987 Z28 Convertible
Transmission: 5-speed
This is true. However, if a subsequent year's tail lights are identical to the previous year, that yearly "number" remains the same. Example. My '87 Z28 convertible's third tail light displays "86". It turns out that this lamp was used on pre-production 1986 Camaro convertibles!
1 Post
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I can walk around a Firebird and tell you what year it is (with hood closed)
85 - (base) same tailights as an 82-84 no high mount brake light.
85 - (T/A) wing spoiler standard optional black aero spoiler new tailights
86 - (base) new tailights - High mount third brake light.
86 - (t/a) aero spoiler standard black only high mount brake light
87 - brake light in the spoiler introduced - 3 spoke steering wheel, will also be the only year (other than 86) with a 85 Mph Speedo.
88 - (base) 4 spoke steering wheel introduced
88 - (GTA) steering wheel radio controls
89 - rear seat seaatbelt shoulder harness' introduced
90 - airbag, but looked like an 89
91 & 92, new facias but I can't tell the two years apart
John
John
John
Memorize the tech database. That'll get you going in the right direction. There are some flaws but they're pretty minor. Anything can be changed, but when you know in general what to look for you can tell a clone from the real deal.
Knowing what was available what years can help quite a bit in spotting a fake... ie 86 & earlier 350's, etc.
I assume you mean visually as they are driving past. these are some visual cues that you can quickly use.
82-84 Z- no real visual differences. Angular sharp lines on front end, Ground effects, silver or gold.
82-84 Coupe- no real visual differences, angular, sharp lines on front end. No ground effects. Had the 3 nostrils between the headlights.
85-87 Z/ IROC- "grid" taillights, the softer. more rounded nose. 85 no 3rd light, 86 3rd light was on the back glass, 87 3rd light was in the spoiler. Z's had the silver or gold ground effects.
85-87 Coupe- same as the Z, but no ground effects. Front nose still had those 3 nostrils between the headlights.
88 Coupe- some had the rear midrise spoiler (early models, switched to the 3 piece late model). All had Silver ground effects with "camaro" emblem.
88 Z/ IROC- grid taillights, 3rd light in spoiler. Z's had silver ground effects (i think).
89-90 Coupe- Body color ground effects, 3rd light in spoiler. (90 interior changed)
89-90 IROC- Grid taillights, IROC emblem on ground effects, bumper. 3rd light in spoiler (90 interior changed)
91-92 Coupe- Grid taillights, the air scoops in the ground effects
91-92 Z28- Grid taillights, high rise spoiler, hood blisters, air scoops in ground effects.
A lot of what I would have said is already posted, albeit I did notice some errors I'm too lazy to address.
One thing that was ommited that most people don't realize I'd like to point out. 1987 Sport Coupes that didn't come with the rear spoiler used the same 3rd brake light as the 1986 models. I've had people argue with me that they didn't, but think about it. If the car didn't have a spoiler then where was the light. There was a federal law that said it had to be on the car. Also I have seen it with my own eyes on a verified 87 model, so I know it to be true. The car was a 1987 LT (this model only offered in 1987 besides second gens which were Type LTs). It had no spoiler as it was a 1SA car, and the third brake light was clearly on the glass up top on the outside just like an 86. So don't assume a Sport Coupe with the outside third brake light is an 86 unless it also has a spoiler. It just might be an 87, which you can identify by the seat material if you know your seat fabric years.
Anyway after that long winded comment you can see why I'm too lazy to point out any other errors, lol. Oh and I'm not trying to sound cocky, just trying to help.
1 Post
Car: 85 IROC-Z
Engine: 406
Axle/Gears: 9" 411
Car: 1989 Formy droptop/88 Deville
Engine: L98 350 TPI
Transmission: factory RWD, WS6 susp
There's a red Z28 locally for sale with the factory sales sticker in the window...however it is a 305 stick and not too fancy. Not my cup of tea.
It is a 1983 though....
Bill
Bill
Car: 1986 IROC-Z
Engine: 5.0 TPI
If you see an RS with 85-90 gfx, it is most likely an 89 through process of elimination. 87 and 88 RS's were only available in certain locations, and 90 was a half year production.
As was already mentioned, there are a number of ways to tell. With the number of models available and the differences on each model, the combination of changes is too many for one post.
cdartz, long time no see or hear. Welcome back
Originally posted by okfoz
I can walk around a Firebird and tell you what year it is (with hood closed)...
87 - brake light in the spoiler introduced - 3 spoke steering wheel, will also be the only year (other than 86) with 85 Mph Speedo...
88coupedoop (04-16-2020)
Car: '92 Trans AM GTA
Transmission: Standard Issue
:hail: :hail: :hail:
GREAT WORK Nightcruzer !
I was often in the dark when trying to figure out what model year I was lookin at.
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
In 87 RS's were avaible in Cali and IIRC only with a V6, in 88 I'm 99.9% sure that what would be consider and RS, actually ahd badging that said "Camaro" and not RS. Then in 89 the rear shoulder belts were introduced, then in 90 the outside looked identical to the 89 but with the major differeance being the dash. With it being more rounded and having an air bag in the steering wheel.
Kat
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
COOL!
i am really amazed by your post nightcruzer,you da'man! :hail: :hail: :hail:
Car: 1988 Camaro Convertible
Engine: 355
I have to add I think you can tell just from the love of the cars. I can literally, on camaro's, tell what year they are when driving by them. Now maybe its subconsciously knowing the differences, but I bet my girlfriend I knew each year. So while driving we have pulled up to an 82, 85, 92 and an 87. The only time so far, knock on wood, that I have been incorrect is calling a 90 an 89... But heck that doesnt count there wasnt enough 1990's
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Might have been addressed already, but I browsed through the thread and didn't see it...
1990 Camaro's are really easy to pick out if you walk up to one. If it has the NON-SCOOPED GFX and an AIR BAG, you know it's a 90! 1990 was first year for the air bag, and last year for the flat gfx. Also, it was the first year for the new guage display...
Bruce (90RS305)
Bruce (90RS305)
Ohh yeah, if you see one with cup holders, it's probly me :lala:
Car: 1982 firebird
Engine: 327 from a 64 vette.....lots of boring details
Transmission: 4 speed manual
for 1982 firebird and trans am....white needles only on gauges....1983 and 84 were orange.
lol
good thread here
#42
Car: 07 Trailblazer SS
Engine: 6.0 LS2
Transmission: 4spd auto
Axle/Gears: AWD w/4.10's
#43
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Rottluver your'e right.Back when the companies changed light design every couple years you could use that but not anymore.My '83 Z28 tail lights are stamped DOT '82 and they continued to '84.
Nightcruzer that is an awesome post.Your example of the '82 - '84 looks like my car,except the color of the car appears white and mine is 59 beige - really close to white especially after 22 years.
#44
Car: 82 z28
Transmission: auto th350
Axle/Gears: stock
I just bought a spoiler on E-bay for my 86 T/A which the guy said came off of an 86 T/A. Mine had a wrap around(shot) so I went with a cheaper and simpler wing. did they sell T/A's with the conventional looking wing also in 86? I realize I will have to fill the old bolt holes and drill new ones to fit the new spoiler(I hope it is that simple) Anyone know if it was a stock spoiler? It looks like the pics of the 82-84 and 85 spoiler
#46
1 Post
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Are the headlights and assemblies different in 91-92 Camaro?
Someone is listing some front end parts from a 91. They posted that the headlights and assemblies are different along with the front bumper?
I know the bottom gfx is different, but the other parts???? Nitro
#47
Engine: 6.0 LS2
#48
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
i know this might be stupidly obvious too, but you can tell an '82-'84 by the GFX alone. they not only are thinner, they also have the vents in the front chin piece...
sorry 83crossfire, didn't see you had already mentioned it...
Josh
Josh
Last edited by screaminformula; 01-06-2007 at 09:09 PM. Reason: comment already mentioned above
#49
thoguht id ad in a tim bit of information.
in 1989 the rs was re-introduced, and years earlyer it jsut was labeled as camaro.
not sure if it was already posted or not.
as for trying to tell waht year a highly modifyed 3rd gen is. id have to say looking at the vin number is the best way.
#50
some clarification on what ErikCamaro said...well, '88 was the ONLY year the Sport Coupe had GFX. so if you see a Camaro with GFX that simply says "Camaro" in the badge locations, it's an '88
the RS could also be had in limited numbers in 1987 and 1988 too...
Josh
Josh
