FAQ Board This board is where some of the most informative and helpful Frequently Asked Questions we get here at ThirdGen.Org are put for easier reference. This IS NOT a general question board.
700R4 Shifter Feels Loose/Has No Effect?
Old Oct 4, 2006 | 04:03 AM
Individual's Avatar
If your 700R4 shifter feels loose and you cant shift into any gear besides the one you are on already, you most likely have a shifter cable problem.
The common problems are the cable disconnecting from the shifter assembly, which can be checked by removing the cover around the shifter/ashtray (1 piece).
If all seems well, look under the driver's side of the car with a flashlight at the side of the transmission. You will notice a cable that runs through a rubber boot into the shift lever. Check if the cable is disconnected.
If the cable is connected, ensure the bracket holding the cable is secure and in place. If not, replace the entire cable. If you are not in the most convienient spot, and you need to move the car, follow these instructions.
If you are alone, make sure you wedge a tire and reach for the shift lever at the side of the transmission and slide it all the way towards the front of the car (Park). Then, click it 3 times towards the back of the car (Neutral) and start it. Reach for the lever one more time and click it 1 over towards the rear of the car into Drive and move out the way. (This method not suggested, use at your own risk).
The suggested method is to have a friend with you holding the brake down while you switch the gears, if you are lucky enough to have someone with you when it happens.
Old Jul 17, 2008 | 01:02 AM
Arctic Cat ZRT's Avatar
Car: 1987 camaro LT
Engine: 350, L98 Heads, HSR
Transmission: TH350
Axle/Gears: 12 Bolt 33 spline 3.55 posi
Re: 700R4 Shifter Feels Loose/Has No Effect?
in my cast of my GM 700R4 it wasn't my shift cable, but my fluid level the dipstick wasn't correct so i added a little more tranny fluid, and it shifts great!!! trie putting alittle more fluid in it!!
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
billybob6110
Sep 23, 2015 01:30 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
