FAQ Building Board This isn't a "question" board. This board is where we all can figure out what we need added/changed to the FAQ on thirdgen.org.
Will 4th Gen rims fit on a 3rd Gen?
Old May 17, 2000 | 08:21 AM
Chuck Everly's Avatar
Not directly, you will need to add wheel spacers or adapters. Using 2.25" adapters on the front and 1.25" adapters on the rear, both the C4 Corvette and 4th Gen F-body offset rims will bolt right on.
Old May 17, 2000 | 04:11 PM
Dirk's Avatar
TGO Founder/Former Owner
Car: 1992 GTA
To add to this, if you get a 4th gen rear, can you run 4th gen rims without the spacer on the back?
Old May 17, 2000 | 09:37 PM
Yes you can run the rear rims without spacers if you use a 4th gen rearend.
The rear ends are a pretty straight forward swap except they are a little wider so there are some changes in the brake lines. This is NOT first hand experience, this is what I have been told so correct me if I am wrong.
Frozer!!!
Jan 19, 2024 04:55 PM
I'llrocya
Feb 2, 2016 11:43 PM
sailtexas186548
Jan 19, 2016 12:21 PM
