1992 Firebird LT-1, 700r4, 700mi on entire rebuild, Se Mi $4000
Car: 1992 Firebird
Engine: LT-1
Car is a 92' firebird (original V-6), t-tops, entire drivetrain has only 700mi (motor, trans, rearend), 4.10, 3500 stall, Autometer gauge cluster, new interior, Mild 96' LT-1, four wheel disc, cd player, and much more. I built the car so I know what exactly is done and have most of the reciepts. I went to the track once as is and ran 12.90 @ 113
$4000 Local delivery or pick up
Car: 1992 Firebird
Engine: LT-1
Do the math, if you plan on making a little hot rod 3rd gen, 4000 is super cheap. The engine, trans, rear-end, and interior are already done.
Car: 1992 Firebird
Engine: LT-1
It wasn't too bad, the intake is actually a GM vortech eliminator intake which I cut the water neck off, and relocated intake holes. Electric fuel pump and helper with a regulator, and the MSD pro billet distributor fell right in the hole.
