FS : 89 Formula 350 - Philadelphia !!!SOLD!!!
Car: 1989 Formula 350
1989 Firebird Formula hardtop 350/automoatic for sale. Maui blue color, 120k miles, pw, pdl, pmirrors, all work - maybe a little slow but they still work. New ABS headliner, does not sag at all. No sunvisors on car right now, I wanted a cleaner look, but I do have them. Center console lid is missing. Couple of dings here and there, but nothing major. No rust holes, some bubbleing paint from where it was repainted (before I bought it), some surface rust on the roof and wing. Exhaust is in need of replacement, there is a rust hole where the muffler inlet pipe connects to the pipe from the cat. Single cat with 3" exhaust on it now with dual outlet muffler (2.25" I think). Power pull down hatch works, and push button release. Headlight motors repaired and working. New goodyear blue silicone hoses, new radiator - aluminum with plastic tanks (still have original heavy brass radiator), new stock type water pump (did not overheat just replaced it with the radiator) new plugs, cap, rotor, silicone plug wires (in trunk) did not install yet. Posi diff fluid changed less than 500 miles ago with GM posi additive and GM fluid (silicone sealer used instead of gasket). Trans was rebuilt less than 2000 miles ago (stock rebuild 3-4 clutch pack went, at least I think that was the one, lost 3rd gear and up, cooler lines were flushed). Optima gel cell battery. This is a daily driver while I fix up my other car but that is almost done and it's time to let this baby go. I have no problems starting and driving this car, I put about 150+miles a week back and forth to work.
Price is set at $3500.
Any questions please ask. I am located in Philadelphia and am willing to deliver the car for cost of gas and return trip. More pictures upon request. Clear title in hand.
All stock, you can see some older pics in my garage (link below)
https://www.thirdgen.org/forums/vbga...ber-40956.html
Trans was rebuilt less than 2000 miles ago (stock rebuild).
more pics here
http://profile.imageshack.us/user/ctechlite/images
more pics here
Re: FS : 89 Formula 350 - Philadelphia
No cracks in dash, dash pocket still has tension in it's elastic, as well as the door pockets. 140 mph speedo, 5500 rpm redline tach.
Bump and adding info...
I took some more pics today, mostly from underneath as someone requested them. Working on getting them up now.
Also wanted to add I had installed polyeurethane motor mounts and transmission mount.
Finally got the pics loaded up
Check them out there.
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
stem49@verizon.net..........Hmm...... Car looks pretty good man . I have the same Maui Blue Formula 350 Hardtop , but it is a 1988. I just blew the Head Gasket in it and now am debating weither or not to just get rid of it and get another Formula , or get the Head Gasket repaired . Some of the parts from my 88 could maybe go on yours if I was thinking of buying it , and I am just 50 Miles away from Philly in Mays Landing NJ. Any way you could PM me with a Cell Number we can talk on ? .....I Am Interested in the Car ...........Mark .
bump, added a few more requested pics
I need to get this moved so I am reducing the price to $1800 cash to the first person to come and get it. Free and clear title in hand. PM or email me.
