[WI] 91 Trans Am WS6 $2000
Want a title? Post!
91 trans am
99,000 miles
350 TPI
New PROM
Powermax 2032 cam
Ford Racing #24 bosch III injectors
older Flowmaster american thunder stainless steel cat back exhaust
B&M Ratchet shifter
I have not owned this car long. I bought the car after a guy had put in a 350 but had not converted the car over to match the 350. So i put in a new custom PROM knock sensor and fuel injectors to match the 350. The PROM is setup to run with the #24 fuel injectors that are in it. The PROM could use fine tuning though. Also other new parts i have replaced since i have owned it TPS, o2 sensor, ignition control modual, spark plugs, and cap and rotor. There are a few other things that are wrong with the car. The alternator currently isnt working but i will be fixing that shortly and the headlights are dim and the headlight motors are stripped. The motors work but they need the replacement gear. I will be also working on the headlight wiring to see what i can do. The body is solid. The hood is not the original hood the previous owner hit a deer and the other hood is shot. and the car needs a front nose the front right ground effect and the peice on the driver's door are broken. Car comes with a new set of outer tie rods but the car needs inner tie rods also. Interior isnt bad but is worn a bit a couple small rips and the cushon on the driver seat is worn down from where u get in and out of the car. The car has no smog pump or cat. The patch job for the cat either needs to be redone or replaced its not very good. The stainless catback system is there but need to be rehung atm its held up with wire again from the previous owners and the tips arnt in great shape. The car needs paint and body work but with a bit of TLC it would be a nice car again. Other then the alternator issue currently the car is drivable and i had been daily driving it and i probably will be once its fixed because until it sells it gets a lot better mpg then my 80 ramcharger.
May Trade for 95 or new GM pickups/Subarban or 18ft or greater enclosed trailer
Fix or Rebuild
Car is Located in Norwalk, WI Feel Free to make offers
Pics can be seen in my profile album(Not Sure how to post pictures on the post)
99,000 miles
350 TPI
New PROM
Powermax 2032 cam
B&M Ratchet shifter
Fix or Rebuild
Car: Looking for a third gen firebird/TA
Engine: 408 ls motor
Transmission: j.w. Th-400/Hawk's third gen T-56
Axle/Gears: Strange S-60
Re: 91 Trans Am WS6 $2000
Got pictures?
1992 Trans Am
05-10-2023 07:19 PM
