Firebirds for Sale Post your Firebird for Sale.
[IL] 1985 Trans Am roller
Old 12-01-2013, 03:39 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Axle/Gears: Moser/Strange 9"
I've had this car since I was 16 years old and it's time to part with it. It is a very clean car with a full stock interior and tons of good parts on it.
Suspension
PA racing tubular K member and A-arms with motor mounts for SBC
Wilwood drag brakes in front and brand new Strange brakes in the rear
Afco front coilovers
Founders performance caster/camber plates
Spohn double adjustable lower control arms and panhard bar
Spohn torque arm and crossmember for TH-400
Spohn front frame brace
Subframe connectors
Rear end
Moser shortened and backbraced housing and 35 spline axles with 5/8 studs
Strange Pro-nodular center section with spool, 3:90 pro gear and billet pinion support
Lower control arm relocation brackets
3.5 inch Chromoly driveshaft with solid 1350 u joints
Afco coilover springs with Comp engineering 3 way adjustable shocks
Fuel system
Aeromotive A1000 pump
Aeromotive A1000 regulator
-12 and -10 feed and return lines
Sumped stock tank
Wheels/tires
15x5 Prostar fronts with 27" front runners
15x10 rear prostars with 28x10.5 ET Drags
Hooker 2210 Super comp 1 3/4 inch longtube headers
Dual 3" exhaust to the rear axle
3" bullet mufflers
Misc
Glasstek 4 inch cowl hood
S10 manual steering box
Strange manual brake conversion with Wilwood adjustable proportioning valve
Battery relocation kit and kill switch
B&M ratchet shifter
All the parts on the car with the exception of a few things are new or barely used. Comes complete minus motor and trans.
I'm starting out at $7500 but am open to offers.
Old 12-04-2013, 12:24 AM
tony1784's Avatar
Car: 85 Trans Am
Engine: SBC
Transmission: TH400
Re: 1985 Trans Am roller
More pics added
Reddeath210
10-06-2015 08:20 AM
Linson
08-31-2015 04:52 PM
Dquickshift
08-12-2015 06:21 PM
drathaar907
08-10-2015 07:44 AM
Quick Reply: [IL] 1985 Trans Am roller
