[NC] 1989 Pontiac Formula 350
Car: 1989 Firebird Formula 350
Axle/Gears: Dana 44, 3.54
VIN#1G2FS2183KL231937
I am the second owner of this 1989 Firebird Formula 350. Drivetrain has about 10k miles.
ENGINE
Block Chevy ZZ1 H.O. 350, 4 bolt mains, .030 over, decked
Oil Pan TPIS with windage screen and trap door baffle
Oil Pump Melling M22
Main Caps Stock Chevy with ARP studs
Crankshaft Forged, polished & chamfered, balanced
Bearings Michigan 77
Rods Pink Rods with ARP bolts
Pistons TRW L-2441F forged blower pistons, dish, (speed pro)
Piston Rings Childs & Albert ZGS gapless
Timing Chain Hamburger billet steel double roller
Dampner Stock Chevy
Flex Plate Stock Chevy
Oil Cooler Stock Chevy
Cylinder Heads Chevy H.O. 350, Aluminum D-port, pocket ported
Valves 1.94 Stock intake, 1.56 stainless exhaust, 3 angle valve job
Valve Springs Comp cams 350# with 10 degree locks and hardened retainers
Rocker Arms Comp cams Pro-magnum rollers 1.52 ratio, ARP 7/16 studs
Valve Covers Corvette Magnesium w/ Metco breather
Push Rods Comp cams Hi-tech 1 piece
Camshaft Lingenfelter 219/.525 straight pattern
Lifters Stock Chevy hydraulic rollers
Intake Manifold TPIS Mini Ram with FelPro gaskets 1505
Throttle Body BBK 58mm with airfoil
Fuel Injectors Kinsler 56.9 lbs/hr high resistance
Fuel Delivery Bosch 90psi inline pump
Supercharger Air-to-air intercooled ATI procharger P1SC self contained unit, 12psi output pulley, Belt-Gatorback Goodyear [4080645] & [8pk1640]
Ignition Chevy HEI, MSD 6A, MSD adjustable timing control, Accel super coil
Pulleys Pulleys & brackets by March Pulleys
EXHAUST SYSTEM
Headers Arizona Speed & Marine 1-5/8 shorty style
Headpipes 2-1/4
Intermediate Pipe 3-1/2
Muffler Walker Dynomax 3-1/2 in, dual 3out
Tailpipes 3 polished stainless, taper cut
DRIVETRAIN
Transmission 700r4 rebuilt by U.S.A. transmissions in Farmington Hills w/high performance parts
Torque Converter Coan Engineering 10 non-lockup special build
Oil Cooler Perma-Cool
Driveshaft Stock, balanced with HD spicer u-joints
Rear Axle Dana 44 with 3.54:1 posi
Driveshaft Loop Spohn performance w/ poly bushing
SUSPENSION
FRONT
Art Morrison tubular lower control arms
Adjustable coil-over springs
Lakewood 70/20 struts
Stock spindles
REAR
Stock control arms, boxed with PST poly bushings
Herb Adams panhard bar
Trimmed coil springs
Lakewood 50/50 shocks
Right side air bag
Herb Adams dual action slider/traction bar
South side machine sub-frame connectors
TIRES & WHEELS
245/50/r16 Front tires by Daytona ZR
255/50/r16 Rear tires by Kumho ECSTA
Street slicks by M&H Racemaster 305/40/r16
Black TransAM crosslaced 16x8 wheels
BRAKES
Stock four wheel disc brakes
ELECTRICAL
Computer Accel DFI v6.0 programmable spark/fuel with Dan White racing interface, tuned by Pandes Performance in April of 06
Battery AC Delco, trunk mounted
Gauges Air to fuel ratio by ATR, MSD knock detector, Vericom VC2000 performance computer, Cyberdyne dash gauges
EXTERIOR
American Sports Car Design ram air hood
Lockable Glass T-Tops
INTERIOR
MOMO three point racing buckle harnesses
Grant removable steering wheel
STEREO SYSTEM
Head unit is Alpine CD player
Amp is 400watt x 4 channel Alpine
Speakers are Sony 4X6 plates & Infinity 6X9 triaxials
I have a new set of performance rotors and pads. Also have original seat belts.
Needs:
-Rear spoiler has cracked
-Front tires
asking $9,900
mr396
09-25-2012 05:00 PM
majorrd
01-11-2008 05:22 PM
