Firebirds for Sale Post your Firebird for Sale.
89 Formula WS6
Old Dec 16, 2022 | 11:07 AM
LeeH's Avatar
Car: 89 Firebird Formula
Engine: 389
Axle/Gears: Moser 4.11
89 Formula WS6
Judging interest on my unfinished 89 Firebird
Located in Northern NJ
Car was painted in 2013, and I have been working on it sporadically since then. I have lost motivation (and I’m not young anymore!)
1989 Pontiac Firebird Formula
WS6 Package
Car is completely disassembled!
New paint, new windshield and windows.
Never fired Engine (built by Haledon machine shop): ZZ4 Chevy 350 4 bolt main, bored 0.30, 383 stroker kit Eagle forged crank and rods.
4 way relief flat top forged pistons, 10.5:1 compression.
Chevy aluminum L98 Corvette heads, summit 1.6 roller rockers,
Comp cams .510/.510 cam, Comp cams dual springs.
Accel Super Ram Intake, Accel large tube runners
SLP 58 MM throttle body, ported plenum
Accel billet distributer, Accel coil, MSD wires
Accel 24# injectors, adjustable Pressure regulator
Speed Density ECM, Custom chip, with zif socket
New Painless 1990 SD engine wiring harness
New (in box) alternator, AC compressor and condenser coil, radiator, gas tank, Walbro fuel pump
New (installed) PS pump, master cylinder and booster, steering box (fast turn 10:1 model)
Drivetrain:
T56 Transmission (rebuilt) , Moser 9” rear, 370 gears, US posi unit
Spohn crossmember, Spohn Adjustable Torque arm (Poly end, also have spherical rod end)
New Mcleod Pressure plate, New SLP clutch
Suspension:
Spohn box welded subframe connectors, spohn adjustable panhard rod, Lakewood LCA’s
New Spohn Tubular K-Member / A-Arms / Coil-Over Package front end. Includes lower control arm bushings, ball joints, inner and outer tie rod ends, 36mm sway bar end links and bushing, center link and pittman arm.
Spohn rear sway bar drop set for the Ford 9” rear
16” Centerline Rims, also have stock 16” Formula Rims.
Exhaust: Edelbrock TES headers, Random Tech 3” cat, SLP Stainless cat back system
New carpet, new door panels
Black leather power seats from 1999 Firebird
2 dash pads in perfect condition.
Many other parts, have many spares, including original K frame and components.
Have well over $25K invested in this car, with receipts.
Asking $15,000.
PACKAGE DEAL ONLY – WILL NOT SEPARATE!
Bring a trailer!
Old Dec 16, 2022 | 07:03 PM
881SA's Avatar
Car: 1988 Camaro Z28
Engine: 5.7 / L98
Axle/Gears: 3.27 BW
Re: 89 Formula WS6
Wow, Your so close to being done. Looks like some very nice work and will be one nice ride when done. Tempting but that would be a long trailer ride. Good luck!
Old Dec 17, 2022 | 12:17 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 89 Formula WS6
What a great start for someone and a great price!
Quick FYI, your centerlink is installed backwards and the inner tierods will install from the back side with nuts on the front.
Old Dec 20, 2022 | 09:09 PM
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
Re: 89 Formula WS6
Wow what a great package, I've seen the build thread and I know you put some meticulous work and time into it. I will need to seriously consider this... is the engine disassembled too? Or on a pallet?
Old Dec 23, 2022 | 12:35 AM
LeeH's Avatar
Engine: 389
Re: 89 Formula WS6
Engine is fully assembled. It is externally balanced, and comes with the correct fly wheel.
JT
Apr 8, 2014 09:29 AM
scholtmj
May 13, 2008 12:48 PM
adambros
Jun 26, 2007 11:37 AM
adambros
May 29, 2006 12:55 PM
