AS&M Big Tube runners - Thread only for the commited ....
I was thinking of getting the Hooker 2055s, failed to mention that. Im probably going to keep the CAT & get a CAT back system. What I was going to do was get the 2055s and the Hooker CAT back, w/ a good high flow CAT. I know for the exhaust Im going to probably spend between $1k & $1500. This car wont be a 400+ HP car. Will be used as a street/strip car. Its my toy basically. Something to restore, bring to the occasional car show, and run it on the track sometimes. Intake & exhaust wont be the only mods for the car. Ing. & some suspension are in my plans.
Car: 1967 Camaro
Engine: 327
Transmission: Turbo 350
Axle/Gears: 308's
I'm trying to order mine, but I cannot register my account there for some reason?
I'm trying to open an account there, and cannot get any info to show on the account info page????
Car: 1967 Camaro
Engine: 327
Axle/Gears: 308's
Thanks for the tip. Not sure why Mozilla didn't work?
WOOT!!! I'm in. Paid in Full....
Fast Toys Performance Parts
Order Number: 713
Order Number: 713
We are now officially at 12 orders sent and 4 to be sent by this Friday (hopefully)
The numbers have been updated on page one......
Car: 1967 Camaro
Engine: 327
Axle/Gears: 308's
Yeah, I know I was a last minuteer myself because I have some ZR1 wheels to sell, and didn't want to use "other money".
They still didn't sell, but I figured what the heck...
Now, I just hope they sell in time for the base manifold GP....
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
CONFIRMATION
order number TEN
i just got the e-mail
Car: 1967 Camaro
Engine: 327
Axle/Gears: 308's
I'm officially official....
hehe...
The comments for your order are
Thanks for your order. You are order # 12 on the GP which ends Friday. After
that, ASM will be building the runners and they will ship once they are
complete.
complete.
hehe... Member
Car: 88 Iroc Vert/ 1980 Z28
Engine: 305 TPI/ 350
Transmission: 700R4/ TH350
Axle/Gears: 2.73posi/ 3.08 Open
My spidy sense must have been tingling, cause I haven't checked the GP board in a while.
SO you can count me in
I was looking at getting some in the near future. But the future is now for that price.
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
I was also cringing at spending $415+ on runners. I will probably order later today. Thanks for this opportunity!
Eric
Eric
Looks like I'll be lucky number 13
Car: A few
Engine: All Eights
Transmission: All kinds
These should work on a 383 with a 224/230 cam and (worked) AFR190s, correct? I also have 3.23s, a 3000 stall Vig and 1 3/4" headers. Sorry to leave the scope of the thread but I haven't had enough luck with searching. Being in CA I dig the stock appearance.
Actually, if they will work I'll need these AND the base. All the rest of the parts are here for the car and I'm going nuts tryign to figure out the induction...
K
K
K
K
It all depends on what you're goals are for the car and how it will be mainly used.
Is it a daily driver? A weekend toy? A full-on race car? etc. etc. etc.
Generally speaking, the rule of thumb is,
If you're looking for high-rpm hp (5500+) go with the stealth ram or an LT1 intake conversion. But if your vehicle is mainly used as a street car, and you spend the majority of your time BELOW 5500rpm, a TPI set-up time like the AS&M/TPIS combo will completely and totally DESTROY the HSR in low-mid range torque department. Torque, afterall, is what makes a car FUN to drive and that's important if this is a car you drive on the streets often....
Be honest with yourself when you're considering what it is that you want out of your motor.
If your building this thing to pull on LS1's out on the freeway, go with the Stealth Ram for sure. Trap speed of the utmost importance? Go with the Stealth Ram. Something different? Go with the Stealth Ram.
For cool looks, drivability, and Big-Block torque, stick with TPI.
It's your call. Only you can answer that question....
Car: A few
Engine: All Eights
Thanks for the reply LT1FUN. As far as this car goes, it has to be legal in CA until we move (a couple of years at this point). If it didn't I'd either go with a modded single plane or the StealthRam.
A car with excellent low-end would be nice for me and the wife. My other car is built for 3K-6+K and even with 3.73s/T5 it's a bit peaky for a stop&go daily driver. I was considering siamesing the plenum to cut the runner a tiny bit hoping for a few hundred rpm. As long as she doesn't fall on her face by 5800, as in BAM, flatline, I'm happy. Like I said, when we're in a free state I'll probably make my own setup. The cam would have to go anyway.
I'm more concerned with the reworked LTR being enough for the combo as it sits, since we might never take it apart again due to having other hot rods to finish. I'd venture to say this car will be a daily driver that sees the track once/twice a month during the season.
If you (or anyone else) have (more) input I'd love to hear it, as I have to pull the trigger on the runners by Thursday night. Again, PMs are fine if I'm trashing this thread. My main question concerns how well the AS&M LTR would work with the parts I bought, as I thought they would work well with an opened-up TPI. After my run I'll probably be on here the rest of the night searching
Thanks again LT1FUN. You're a big help.
K
K
Car: 1985 Z28
Engine: 85 L98
hey there KenV.
.Articles That Use Comp Cams® Products
that link should help.
i myself will be biulding a 383 tpi with the AS&M runners and TPIS base.
but unlike the article i will be useing some 180cc AFRs pro. compition ported.
Car: A few
Engine: All Eights
Hey, thanks man. I read the article a short while ago. They seem to be doing well with a cam two steps up from mine (I have the 276HR), so I think mine will be a beast in the midrange.
If I do boost later, I have a 218/224 blower cam from Comp in the garage. I think that would take care of the RPM limit to an extent. Not that I'd care
Looks like I'll get in line for these runners tomorrow (have to head out for a sec now). I'll light up the plastic from work tomorrow with the details from the first page of this to guide the process. Thanks a ton for the advice folks! And thanks for setting this up LT1FUN.
Ken
Ken
Engine: 357 SBC TPI
Hot Diggity! I just ordered and am awaiting comfirmation.
Thanks TGO!
Eric
Am I #15?
Thanks TGO!
Eric
Am I #15?
Car: 87 IROC
Engine: 5.7 TPI
I am having a serious problem w/ fast toys! I have placed my order. Order number is 707. There are telling me that I need to contact my credit card company and give them the address of where I am having them shipped since it differs from my billing address.
The thing is that the card I am using is not a credit card it is a check card w/ a visa logo. I have used this card before to send things to addresses that are not my billing address. I have called and emailed them to let them know that but my order still says waiting for customer reply.
Im getting really fustrated about this seeing as it is Wed. and its the samething w/ them over and over and I feel like I am going to miss out on thr GP b/c of the stupid situation. Anyone ever have this problem b4?
Couldn't you just ask fast toys to ring it through with your mailing address but then ship it to the address of your choice after proccessing?
UPS won't ship to a po box so I had to give fast toys another address to ship to and it was no problem.
Car: A few
Engine: All Eights
Okay, add me to the list. I just bought a set for the '90, comment field filled out and all. I didn't get any errors so all seems well right now. What a deal. Thanks to all involved on this one. I can't wait to get my baby back on the road
K
K
Just let them know what you've told us and I don't see why there would be any problems submitting your order.
Talk to them and make sure they know what's going on. But you have to talk to an actual person to clear things up. Emails usually aren't good enough in situations like this.
Did you actually speak to anyone? What did they say?
By the way, we're at 14 orders submitted and counting
Page 1 has been updated to show the latest numbers.
Demon355 will submit his order tomorrow so that'll bring us to 15. Not sure yet if the other people on the list are still going to be placing there orders as I haven't hear back from them with any updates, but regardless, we've met the minimum amount of buyers anyway.
The deal's all but sealed now, gentlemen !
My order is submitted but you don't have my name in the list on the first page.
P.S. I am interested in the TPI intake manifold purchase depending on the price of course.
Car: 08 Suburban, 87 MCSS, 89 IROC
Engine: 5.3, 355, 350TPI
Transmission: stock, 200-4r, 700R4
Axle/Gears: stock, 3.73 posi,
Just ordered mine, do you have to wait for the order confirmation with the shipping costs to see the updated sale price?
Just kidding man. The list has been update accordingly. Along with ramos87ss' order that was just submitted, we're now at 16 ORDERS !!!!!
This is definetely one of the more successful group purchases I've started, without question.
If we can get the same amount of orders for the base G.P. 3rdgenZ's getting together, that'd be mint !What the heck took you so long??
We never heard back from you again since that first day the thread was posted. You've been M.I.A. ever since......
I've been lurking around a little. I told you guys it would be either today or tomorrow. I wouldn't leave you guys hangin even if you didn't get to the 10 amount I was still in. I've been watching on the tpis base post, really interested in seeing how that one goes.
Car: 87 IROC
Engine: 5.7 TPI
No I didnt speak to anyone. Everytime I call I get the voice mail. All this will really suck if I miss out. Im going to try them again today. As far as talking to the bank. Ive used this same card to make purchases over the net before and ship to the same address I giving fast toys to ship the runners to. I dont see what the big f'in deal is.
On top of all this Im in the military in Iraqi right now so its not like I can call constantly till I get someone. Im getting annoyed w/ all of it. Ill try again today and post my results later...
You say you've called them, but were you able to actually speak to anyone? Or did you get a machine or something?
Car: 87 IROC
Engine: 5.7 TPI
Well I got good news from fast toys. They said they would process my order w/ the instructions I have given them and if there is a problem they will contact me. Hope everything goes smoothly.
Engine: 357 SBC TPI
You'd think that since he's placing his life in harm's way for our country, they'd cut him just a LITTLE slack. Thank you navyCM.
how long does it take to get order confirmation, i ordered mine last night and haven't heard back from them today yet.
Great news! Glad to hear it man. I'm sure everything will go smoothly.
That's right gentlemen, we're now at 18 orders and counting. Page one has been updated with the latest numbers...
If anyone's just getting in on this now, if you're interested, act fast as the deadline is TOMORROW!!
If you pass up this oppertunity now, you're missing out on getting the best runners on the market, for the same price of bargain basement SLP's
Don't miss out on this great oppertunity!
Car: 87 IROC
Engine: 5.7 TPI
Thanks for the comment I appreciate it. I never thought this would take off like this. I figured we'd get the 10, but damn we've nearly doubled that. Hope the base GP turns out this good.
Is there anything else we could GP for, other than the base? I just got my car so I need pretty much anything for it.
Engine: 357 SBC TPI
How about polished 52mm TBs? Like the one Summit has, or the Holley version (which is WAY overpriced)
I need 30 lb fuel injectors too, let's get Venom to Gp those!
Maybe custom chip programming (PCMforless)?
Spohn 1LE brake package? March pullies? BECOOL aluminum radiators?
Yeah, I pretty much listed most of my supply list!
BTW, I may be out of the base GP as I won the Accel one from ebay for $295...unless it turns out to have a 30* bend or something.
BTW, I may be out of the base GP as I won the Accel one from ebay for $295...unless it turns out to have a 30* bend or something. Member
Car: A few
Engine: All Eights
Got an email last night from FastToy's and they said they've now received 16 orders.
Hmmm.......
18 have said they submitted their orders but only 16 have been received by FastToys. Weird.
We'll see what the final count is later on today. I'll post up FastToy's official tally when they contact me later and let me know.
Anyways, 16,18, whatever. Looks like we're in anyways.
Hmmm.......
Car: 87 IROC
Engine: 5.7 TPI
I hope Im not one of the 2 left out. Id be so pissed. Did we need to let Fast toys know our year model so we get the right runners?
Car: 1989 IROC-Z
Engine: 5.7
Transmission: 700R-4
Axle/Gears: 9-Bolt Borg-Warner 2.77
I just placed my order!!! Just sold a SLP MAF last night that gave me enough to do it!!!!
I am pumped!!
I am pumped!!
