Group Purchases Take part in, suggest, or discuss Group Purchases here. Make sure to read the rules before doing so.
c5 front brake conversion brackets!
Old Mar 8, 2010 | 03:56 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I have a machinest that is cnc'ing some brackets for the c5 conversion. If we can get 10 sets ordered he will do them for $40 a set.
Let me know and I will pass along the info. His company is a sponser on pro touring . com so he is on the up and up.
Old Mar 10, 2010 | 04:12 PM
Car: 1971 Camaro
Engine: 427
Re: c5 front brake conversion brackets!
Anyone? This is quite a deal! Cheaperst I could find elsewhere was $75.
Old Mar 10, 2010 | 04:37 PM
Stephen's Avatar
Car: 87 GTA
Pics of what your building? More info?
Old Mar 10, 2010 | 05:43 PM
Car: 1971 Camaro
Engine: 427
CNC steel brackets, just like the ones here,
http://www.bigbrakeupgrade.com/products2.htm
Based off the file here,
http://www.lukeskaff.com/car/brakes/bracket.html
Bottom bracket for c5 calipers.
I am not making them, I posted on another site looking for a company that could make some for less than $75, and SDS Machining offerd to build them for me.
Here is their site,
http://www.sdsmachining.com/
He said if I could get 10 people that wanted them, he would build them at the price of $40 a set.
Old Mar 17, 2010 | 08:28 PM
Car: 1971 Camaro
Engine: 427
Brackets are done and ready to ship!
Should have mine Monday.
Again, if anyone wants some, let me know, and I will give you the contact info.
Old Mar 17, 2010 | 11:59 PM
Stephen's Avatar
Car: 87 GTA
So....Are you selling these at $40/set? Or are they coming directly from SDS?
Old Mar 18, 2010 | 01:31 PM
Car: 1971 Camaro
Engine: 427
They will come directly from sds.
Pm me for the contact info, if interested, as this is not something they normally sell.
I simply did the leg work and got them to make me a set.
Old Mar 18, 2010 | 03:47 PM
Car: 1971 Camaro
Engine: 427
SDS has posted pics here.
http://www.pro-touring.com/forum/sho...763#post647861
Old Mar 22, 2010 | 02:04 PM
92-Formula's Avatar
Would these be compatable with C6 calipers as well? Any other modifcations required to the spindles? I'll be interested regardless...
Old Mar 22, 2010 | 03:49 PM
Car: 1971 Camaro
Engine: 427
I do not know about c6 calipers.
As with all the other upgrades out there, you will have to cut the old caliper mounts off the spindle, and drill out and re tap the 2 holes.
Old Mar 22, 2010 | 04:32 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
thats a really good price.
Old Mar 22, 2010 | 04:43 PM
Stephen's Avatar
Car: 87 GTA
It looks like SDS went with aluminum stock instead of steel, right?
Old Mar 22, 2010 | 07:09 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I would only use 1/2 steel and you still have to make hubs. Make sure you use grade 13 bolts with safety wire holes.
Old Apr 27, 2010 | 09:22 PM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
This price still available?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
