can you rotate 91 gta rim/tires?
Old 04-21-2002, 03:58 PM
91fbirdgta's Avatar
Car: 91 Firebird GTA
hey guys, I was checking out my rims-and noticed that the front and back rims look different-anyone know what I'm talking about-the front ones seem to be wider where the gold honeycomb part of the rim meets the silver part-
so my question is, can I rotate them or not?
and one more thing-whats the widest tire I can put on that rim-I currently have 245/50/16's all around and was wondering if I can put 275/50/16 in the rear-would that fit?
thanks
Old 04-21-2002, 04:47 PM
Guest
Guest
Posts: n/a
You cant rotate the rims, the offset is different front-rear. The rears if you put them up front will rub when you turn. Might even rub stuff without turning.
Old 04-21-2002, 10:26 PM
91redgta's Avatar
255/50R16 tires are the widest that will fit on those rims
Old 04-22-2002, 12:16 PM
91fbirdgta's Avatar
ok, thought so-but just wanted to be sure-thanks for the info guys
Old 04-23-2002, 02:20 PM
bradkeith's Avatar
Don't let someone at the tire store talk you into not rotating your tires because of your rims. Your rims need to stay in place, but the tire store will need to dismount/mount re-balance your tires into the appropriate positions.
Old 04-24-2002, 10:17 AM
karfreek's Avatar
Right, or the rims will rub the front struts.
Jay
Old 04-24-2002, 11:32 AM
Drew's Avatar
Received 1,052 Likes on 748 Posts
Actually with 245's and the rears mounted on the front, the wheel will rub the tie rod. It makes a nice growling noise and will knock off any wheel weights, and will put a nice groove in the clear coat.
This is why I take the tire shop only my wheels, not my car. Not to mention that my cars sit too low to drive onto their lift equipment. And that they like to tighten the lugs with impact wrenches.
bigjay89gta
10-15-2015 08:04 AM
2012sergen11
10-13-2015 07:38 PM
Eric-86sc
09-28-2015 11:37 AM
Dragonsys
09-25-2015 03:51 PM
Quick Reply: can you rotate 91 gta rim/tires?
