Option package 02
Subscribe
May 2, 2002 | 05:36 PM
I did a search for this and was unsuccessful, could someone direct me to a thred or tell me what it includes. Also what is an ornamentation, aero package. What does E72 : BODY LENGTH, INCR I8 INCH mean. My car also has T-tops but no RPO CC1, is their another RPO that would indicate this, or were they installed by a previous owner? Thanks
Reply 0
May 2, 2002 | 06:51 PM
Reply 0
May 2, 2002 | 07:04 PM
Yeah thats right. It is an 89 IROC with a 305
Reply 0
May 14, 2002 | 06:44 PM
anyone about option 2?
Reply 0
May 14, 2002 | 06:58 PM
pw, pl, ph, floor mats, tilt, cruise, air, am/fm cass, aux lighting.
T-tops should have CC1, if not they're after market. your last code is probably E7Z, not E72
Reply 0
May 14, 2002 | 07:02 PM
Out of the things mentioned my car has pl, ph, floor mats, air, am/fm cass, aux lighting. It dose not have floor mats but they were probably removed. May not have cruse because it is a standard trans.
Reply 0
May 14, 2002 | 07:18 PM
Do you have your RPO code sticker in the console?
Reply 0
May 14, 2002 | 07:24 PM
Yes
Reply 0
May 14, 2002 | 07:29 PM
I've got an 87, with option level 2. My rpo code lists that option level 1SB, and then also lists all the RPO codes that came with that package. Yours, should be that same.
so do you have B34, b35 = FLOOR MATS?
k34=CRUISE CONTROL?
Reply 0
May 14, 2002 | 07:43 PM
I have 1SB also but no B34, B35, K34. I have D34 and D35
Reply 0
May 14, 2002 | 07:50 PM
Well now you have got me confused , could you possibly post a picture of you car and your RPO sticker? I'm not trying to flame ya, I'm just confused b34 nad b35 sould be floor mats etc.
Reply 0
May 14, 2002 | 08:02 PM
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
A01 : WINDOW, TINTED, ALL SHADED, W/S
B18 : ORNAMENTATION, INTR, DELUX
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D34 : MIRROR, VISOR VANITY
D35 : MIRROR, OUTSIDE REAR VIEW
D7L : GEAR, SPEEDO DRIVEN
D80 : SPOILER, RR END PNL
D88 : DECAL, STRIPE, SPORT
E5Z : SPEEDOMETER ADAPTER (DELETE)
E7Z : SENSOR, VEHICLE SPEED (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
GU4 : AXLE REAR, 3.08 RATIO
G80 : AXLE POSITRACTION, LIMITED SLIP
IPC : TRIM- INTERIOR DESIGN
J50 : BRAKE SYSTEM, POWER
K68 : GENERATOR,105 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NP5 : STEERING WHEEL, LEATHER WRAPPED
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
PF2 : WHEEL, 15 X 7, ALUMINUM
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
Unable to locate code R6C in our database!
TR9 : LAMP, GROUP
T93 : LAMP, TAIL & STOP, SPECIAL
T96 : LAMP, FOG
UA1 : BATTERY, HEAVY DUTY
UB3 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UQ1 : RADIO PROVISIONS, FOR STEREO
U25 : LAMP, INTR, RR COMPT, COURTESY
U26 : LAMP, INTR, ENG COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN : ASSEMBLY PLANT, VAN NUYS, CA
V73 : ANTENNA, FIXED
WW8 : APPEARANCE PACKAGE(BRIGHT RED), AERO #8
W62 : ORNAMENTATION, AERO PACKAGE
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY : 1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
1SB : OPTION PACKAGE 02
1SZ : ???
16P : WHEEL COLOR, BRT WHITE (91)
19C : TRIM COMBINATION, CLOTH, BLACK (C) (91)
19I : INTERIOR TRIM, BLACK (I) (91)
199 : SEAT BELT COLOR, BLACK (91)
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZW : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL : SPRING ,COMPUTER SELECTED, REAR, LEFT HAND
81Q : MOLDING COLOR, BRIGHT RED (91)
81U : PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
86A : STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Reply 0
May 14, 2002 | 08:21 PM
Here
Reply 0
May 14, 2002 | 08:22 PM
Try again
Reply 0
May 14, 2002 | 08:27 PM
Well now I'm really confused! but thanks for posting your RPO codes. Maybe Drew or Willie can shed some light on this.
My info comes from the Camaro White book, maybe the book is wrong!
Nice Car
Reply 0
May 14, 2002 | 08:30 PM
here's mine:
Reply 0
May 19, 2002 | 07:05 PM
Any ideas Drew or Willie? Thanks
Reply 0
May 19, 2002 | 08:20 PM
Do your t-tops look like this? :
If so, then you have aftermarket Cars & Concepts tops like on my '88 IROC. Note the trim piece at the front, and the wider than stock pillar along the top of the windshield.
Reply 0
May 21, 2002 | 02:17 PM
Yeah they look like that , but what about the missing rpo from option package 2?
Reply 0
Subscribe
